biosurfer1's Avatar
Warm-up problem and mixture question...
I have been having a problem with warming up and doing a search for the solution, i come up with mixed results. Starting the car cold is fine after replacing the fuel accumulator, however if the car is cold, it idles high at first as it should, but once the aar closes, the idle surges, making the car die occasionally, until the car is warm, at which time it idles great. reading old posts, i figured that the air/fuel mixture was off and needed adjustment, but before i do that, i wanted to make sure this is the answer. i also read in old posts that if your mixture is correct, taking the oil cap off should cause the idle to drop a bit, which mine does, so does this mean my mixture is ok, or could it still be off? if it is off, is it too rich or lean? how can i tell once the mixture is correct besides waiting for the car to cool down and check the warmup idle? thanks for the advice...
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 04-30-2005, 10:48 PM
Designer King
Paulporsche's Avatar
Idle speed surging usually indicates a too rich mixture. Try turning the screw accessible on the top of the mixture control unit counterclockwise in 1/16 turn increments until the surging stops. You can also search for and use the push/pull method for setting the mix. Or you can have it set to 3.5% w/ a gas analyzer. When you lean the mix, you usually have to lower the idle speed. Do this by turning the screw on the side of the throttle body clockwise. Backfiring through the intake or popoff valve popping means a too lean mixture.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-01-2005, 06:47 AM
