What holds in the center dash vent ?
My center vent keeps falling out what should hold it in ?
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 04-30-2005, 08:46 AM
Air Medal or two
afterburn 549's Avatar
mine is just a push fit
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 04-30-2005, 05:30 PM
jyl jyl is online now
jyl's Avatar
Assuming you mean the center vent to the right of the gauges, where the A/C comes out. There are spring loaded clips at either two of the four corners or all four corners. If you peer inside with a flashlight you should see little metal bits, that's them. If your vent falls out and there are no clips, then probably just buy a used vent with the clips.
Old 04-30-2005, 06:43 PM
