If laid out flat, how long is the 911 muffler strap from bend to bend? I have two stainless straps that I am planning to use, but they seem to be too long. The straps that I have are 23 inches from bend to bend.
Thanks!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Come on, guys, this is probably the easiest question ever posted on this BB! Someone out there must have a muffler strap they can measure!
Thanks,
Friend of Warren
Actually they are different lengths depending on if you have an early or late 911!
Kurt V No more Porsches, but a revolving number of motorcycles. |
Not as it seems
mine are on the car so measuring them is tough.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I have a single strap in my garage. I can measure it this evening when I get home. The one I have is for an early car though, so if they were different lengths, it won't do you any good.
John |
for me, they only were in either of the two sizes: "not long enough" and "too damn long" which required cutting one and riveting it closer together... Ben's muffler is such a slim piece
dave 1973,5 |
As it turns out, the muffler straps need to be about 21"-21.5" between the bends. This is based on using a "74 mounting bracket and an Ansa muffler (2 in / 1 out). To resolve the "too long" problem, I marked the strap, measured 1 1/2" and made another mark. I then drilled an 8mm hole thru the straps and cut them half way between the holes. I then bolted the two pieces together and "Voila" they would then work.
Depends
Re: Muffler strap length.....
Had a 3-day weekend at MidOhio and wonder whether the heat killed the rivets or whether the metal expanded and the rivets were smallish and fell out...
dave 1973,5 |
