copper's Avatar
Shifting difficulty
The engine is now back in and the new clutch, flywheel and pressure plate are in. I've checked the shift coupler and it is attached (was off for the drop).
Clutch is nice and strong. The only problem is, which is different than before, I cannot put it into first from a stand still without grinding the gears. Regardless of double clutching or adjusting revs, she just wants to grind. Also, when coming out of first, there's a noticeable resistance and a dull thud when coming out. Other gears are all fine.
All was smooth before, with the exception of the worn clutch.
Any thoughts?
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 05-04-2005, 04:32 PM
Driving member
jester911's Avatar
Might need to readjust the coupler.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 05-04-2005, 04:54 PM
Grady Clay's Avatar
That sounds like the clutch isn’t completely releasing. The dragging clutch overwhelms the friction of the syncro. The reason it “pops” coming out of gear can be the gear is loaded from the clutch not releasing fully so it is still loaded.
Will it go into reverse at idle without grinding?
Did the clutch cable get wound around the parking brake cable?
Are there ALL new parts, including flywheel? Did you compare the old parts to the new ones?
When the clutch is fully depressed, is the clutch release fork touching the opening in the transmission bell-housing?
Don’t let it grind 1-5 while testing; that will damage the syncros.
Best,
Grady
PS, one of these days I’ll tell you my ’70 RCMP story.
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 05-04-2005, 04:55 PM
Navaros911's Avatar
I'm with Grady on this one... sounds like the clutch needs adjusting... this is easy, so start there.
There should be a tech article where clutch adjustment is described.
'94 964 - Celebration 30 Jahre edition
'06 997 - arctic silver with cocoa interior - sold
'77 RoW 911 - black and still sexy - sold and I miss her
'05 Audi A3 Sportback 1.9TDI (not a bad daily driver) - gone
Old 05-04-2005, 05:09 PM
copper's Avatar
You guys are bang on. I did some deeper looking through other threads AFTER I posted this one. I gotta remember to utilize the search function more.
The clutch wasn't adjusted properly. Wasn't fully disengaging. Now it's adjusted properly and the shift is smooth as silk.
Thanks a bunch!!
Jim
Old 05-04-2005, 08:54 PM
