EBS Cylinders
Has anyone tried the EBS 95mm to 98 mm bored and re-nicasiled cylinders and JE pistons? I'm considering these for my 3.0 to 3.2 short stroke build-up. Any info would be appreciated.Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Irrationally exuberant
EBS is great. I am in the middle of building up a 3.2 short stroker for a customer using their 98mm P&C right now. I don't think it is EBS's fault but the 2 sets of "9.5:1" JE's I bought from EBS both CC'd out to 10.5:1. I'm going to machine them down to 9.5:1 tomorrow. If the project wasn't so far along it would be perfect excuse to go with the twin plugs solution BURN-BROS is selling.
(Twin Plug Goodness...Look what I made this weekend!) -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris can you post before and after pics of the pistons?? I would like to see what they look like after machining. Is there a part number on them that indicates their compression ratio?
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
10.5:1 -> ~41.7cc 9.5:1 -> ~35.2cc Mine measured out to 39.5cc -Chris
Thanks Chris. It's my intent to go the hi-comp, twin plug route.I've been trying to find negative comments about EBS .. so far I havn't found any... Chris how are they with other machining operations? Is it done in house, or sent out?Dan
I haven't used EBS for machining so I don't have any personal experience but I *think* they have a good rep. They send their stuff out AFIK
-Chris EDIT: I forgot, the customer supplied rods were done by EBS and they look good but I didn't measure them. I know I should have but they felt good on the crank.. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 05-02-2005 at 03:10 AM.. |
Chris ,since were on the subject .. who do you recommend for machining operations. Such as rod rebuilding, head work and balancing. Dan
installing 3.2 to 3.4 EBS re-nicasils now. I'm hopeful.
-Chris
Again ...thanks. That reinforces my plan of sending the heads to a Porsche specialist and the other parts to my local machinist.Dan
-Chris
MBruns for President
I'm going the 3.4 route myself - although I bought Eric Hood's c2 turbo cylinders that had been bored to 98mm.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I just finished getting my 2.4 back together yesterday. Started right up and runs well.
I used EBS for all of the hardware purchases and Ollie's Machining in Santa Ana, CA (both advertise in mags). I can't say enough about both of these companies. They were very knowledgable and helpful. The prices were very fair and neither of them tried to sell me anything I didn't need. In fact, Ollie's went out of their way to allow a DIY'er such as myself to do a few things with their direction that saved me about $400. Both delivered everything correctly, on time, and as promised. Good luck with your project! |
Here you go. As you can see, very little was removed. The "Before" piston is the one on the left. I weighed a piston. Then my friend Palmer took a few passes with the mill, matching the original angle of the top. Then we checked the dome volume, and repeated the process until got the compression I was looking for. We compared the after machining weight to the premachiing weight to determine how much material was removed. For the rest of the pistons we simply removed the same amount of material (by weight) from the top. Dome volume before: ~39.5cc, compression 10.5:1 Dome volume after: ~33.2cc, compression ~9.6:1 Material removed 5.7 grams (Deck height=1mm, head vol=87.8cc) This motor will be running with knock sensing so I picked a compression on that was conservative yet fun to be around. ![]() -Chris
