Porsche-poor's Avatar
The final answer is????
I did a little research on the CV joint and now I'm even more confused. Seems there are at least four camps. One with plates and washers, one with none at all depending on the year of the car, one with loctite (blue) and one that uses safety wire for racing.
Bentley book shows plates with no washers, 101 projects (page 116) has a picture of the CV joint with what appears to be a real dirty CV joint with no plates and no washers.
I replaced the transmission side seal and found no plates or washers. What's correct?
'79SC Targa
'2021 CRV
Old 05-04-2005, 07:17 AM
Senior Member
Superman's Avatar
My belief is that, for your car, you use the plates and the Schnorr washers. I have heard of CV joint bolts backing out, and I've heard of CV joints coming loose and falling off. So for me, the plates and the Schnorr washers are minimum and critical. This is also a good location for safety wire.
Mocha 1978 911SC. "Coco"
Old 05-04-2005, 07:27 AM
What did your torque them too? I was a bit confused by the diagram in the Bentley manual and the torque for the CV joint bolts that enter the transmission vs. the bolts that enter the back of the wheel.
1980 911SC Targa 3.6L
Old 05-04-2005, 07:34 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Re: The final answer is????
42.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 05-04-2005, 07:35 AM
Based on the chart on 390-3 I torqued them to 30 ft-lb
'79SC Targa
'2021 CRV
Old 05-04-2005, 07:38 AM
42-HA!
Charlie
89 911 Cab
Old 05-04-2005, 08:14 AM
By shear luck 42Nm just happens to be the answer to JonT's question.
'79SC Targa
'2021 CRV
Old 05-04-2005, 08:33 AM
