225 60 16 pros/cons
I'm running 215's on all four corners now which look and handle fine on my 74 w/ SC flairs. So I was thinking, next time, why not 225's?
Pros:
Better ride
Better mpg due to higher effective gearing
Fills fender openings better
Bigger contact patch
Bigger selection to chose from
Cheaper
Cons:
Slightly slower off the line due to taller effective gearing
What else?
Cheers,
Joe
Old 05-13-2005, 07:39 AM
rdane's Avatar
SC flares? Why not the 225/245 combo?
Old 05-13-2005, 07:44 AM
rjay's Avatar
A love of oversteer, perhaps?
Tailwagger NER/NCR PCA, SCCA, NASA, COM
2000 996 C2 Aero Brumos 59 Special Ed.
1970 911 3.2L RSR
Old 05-13-2005, 08:04 AM
Oversteer has never been an issue even after going from 7's/9's down to 6's all around.
I like the idea of being able to rotate my tires now to even out the wear.
Joe
Old 05-13-2005, 08:42 AM
rdane's Avatar
Then 225s would seem to be the obvious choice. No way a 225/60 will fit up front though on most cars. 225/50s have a hard time.
Old 05-13-2005, 08:47 AM
One other con is that you lose a lot of the great steering feel of an earlier 911 with front tires that wide.
Old 05-13-2005, 08:50 AM
I know I had some rubbing issues with the 215's. Seems my left front tire was hitting the back of the valence when I turned right. My solution was to carefully pry the valence forward slightly with a 1"x2" wooden handle. I have a feeling that the 225's might just need a bit more tweeking too.
Joe
Old 05-13-2005, 08:55 AM
I cannot imagine how going one size larger would make that much difference feel wise. But then it's not that big a concern for me anyway.
Joe
Old 05-13-2005, 09:03 AM
I just thought of another Pro: Lower rpms at 65
Less noise
Less engine wear
Old 05-13-2005, 09:10 AM
your trying to make a 911 into a cruiser .. not always easy to do ..
2006 Cayman S
93 RS America white(now living in Arizona)
1974 911S/CARRERA (now living in Australia)
Livermore Ca.
Old 05-13-2005, 09:19 AM
Not that easy to cough up the change for a 993 or 996 either.
At least more rubber might be a small step in the right direction.
Old 05-13-2005, 09:57 AM
