-   -   How to get to back up switch (http://forums.pelicanparts.com/porsche-911-technical-forum/220036-how-get-back-up-switch.html)
scarletbegonias 05-05-2005 03:43 PM
My reverse lights aren't working. The bulbs look good, the fuses are fine, so I'm thinking I need to replace the back up switch. When I've done a quick look under the car, I can't find it. Based on pictures and parts diagrams I know where it's supposed to be, but the transmission carrier seems to be in the way.
http://forums.pelicanparts.com/uploa...1115332851.gif
Do I have to remove the transmission carrier to get to the back up switch? Or do I just need to get the car raised up higher to get a better angle to look for it.
Also, after I find it, I think I've read that I can disconnect the wires and touch them together - this will light the reverse lights and tell you the back up switch is defective. Is this correct?
Thanks,
Howard
MotoSook 05-05-2005 03:50 PM
Howard,
You don't need to remove the tranny mount. You will see the boot over the wires leading to the switch when you are under that area. Pull the boot back and use a pair of needle nose piles to extract tthe bullet connectors. And yes, the touching the connectors should light the reverse lights. The switch is a contact switch...
FrayAdjacent911 05-05-2005 05:37 PM
Reminds me... I need to fix mine... and I'll be very close to passing inspection!
rcecale 05-05-2005 05:56 PM
Howard,
For reference, here are a couple of pics that may help you find it.
http://forums.pelicanparts.com/uploa...1115340908.jpg
http://forums.pelicanparts.com/uploa...1084732884.jpg
And I do believe you are correct in your assumption that touching the two wire terminals together will cause the lights to light.
Hope these help!
Randy
edit: These are pics from a 915, not sure if the 901 is different or not. :)
crashr 07-19-2009 09:34 PM
Does anyone know what type of electrical connector porsche used for the reverse light connection on the 915 transmission? (In the picture above) Mine had been cut off. I tried to replace them with the bulletstyle electrical connector but they are a little small so they just pull back out.
euro911sc 07-20-2009 08:00 AM
Yeah those male member shaped pins are a pain to get. Basically have to salvage a wire harness... or make new ones. FYI I replaced my switch and still had trouble with reverse lights... turned out the pin in the shift shaft had been moved during the last rebuild and was missing the switch... noticed it right before I put the nose cone on after another rebuild.
-Michael
pete917 07-20-2009 08:43 AM
My reversing lights stopped working and after a long search it turned out the wires had worked themselves out. Pushed them in and job done. Its never normally that easy :)
crashr 07-20-2009 12:48 PM
So there is no standard bullet connector tha twill fit in there. I saw something on the internet about Japanese bullet connects which kind of looked like the right shape.
crashr 07-22-2009 11:40 AM
bump
donporfi 07-22-2009 12:06 PM
Check Eagleday probably they have what you need.
http://eagleday.com/busnco.html
crashr 07-22-2009 02:06 PM
Thanks this looks like it might be them.
DagoDewop 07-31-2009 06:36 AM
So, Dennis.
Did the Eagleday connectors work work for you? If so, which ones did you order?
-T
HawgRyder 07-31-2009 07:15 AM
You can use regular bullet type ends for the application if you apply solder (melt some on) after you crimp the end on the wire.
What you are trying to do is increase the diameter of the connector.
If you get the correct amount on, it will be a force fit into the receptacle.
Bob
