Banned
Tensioner Failure
Can anyone tell me what symptoms I would have with tensioner failure? What kinds of things can i do to check for failure??? Any threads on how to fix or replace tensioners??? Thanks, Mark
Old 05-11-2005, 10:02 PM
scottb's Avatar
Mark: Use the search button in the upper right hand corner of your screen. You'll find dozens, if not hundreds, of threads dealing with tensioners.
I've heard that a failed tensioner sounds like a chain being dragged across a trashcan. Fortunately, no personal experience.
Good luck.
1984 Targa
Old 05-12-2005, 01:49 PM
ckissick's Avatar
Well, I do have personal experience, and it does sound like a chain being dragged loosely over someting, because it is. Not so much a metal trash can, more like a plastic trash can, because its hitting the plastic chain guides.
For me, the sound only came at low RPMs, especially as the engine decelerated down to an idle, when I could here the sound between 2000 and 1000 RPM.
There's another sound to look out for: a loud clunk, like a sledge hammer hitting concrete, when you try to start the engine. That's when you drop the engine or call a tow truck. I know that sound, too. And the tensioner had only 100 miles on it. On a bright side, when I had it fixed, I had them put in a 20/21 cam and added some extra HP.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 05-12-2005, 03:29 PM
I second that - mine happened on decellerating at a junction, right outside a Porsche main dealer, at very low revs! Can you believe that? Must have thought it was going home to mama!
I heard two sounds - the first exactly as described by Charlie, the second my wallet hitting the floor ;-)
It wasn't too bad in the end. I had none of the pistons hitting valves stories you hear. I was lucky. I drove 50 yards onto the forecourt and just told them to fix it!
Old 05-12-2005, 04:14 PM
Banned
Tensioner?
Pete, Had you lost any power when the tensioner went?? Jump timing? Im looking at a car that supposedly has lost power and has irratic timing. Head valve job now?? Thanks, Mark
Old 05-12-2005, 04:32 PM
Hard to say - I was slowing down, almost came to a stop, did not have to, pulled away, then the noise kicked in. I instantly new what it was and turned onto the Porsche dealer forecourt - all happened in twenty seconds at low revs. I guess there was reduced power, but I was too scared to really test it. It just sounded like a bag of spanners. The chains did not jump at all, they were just loose.
I know when it happened to me, I scoured this board, and it was invaluable. You will find some answers, and some very knowledgeable folk, here.
Old 05-12-2005, 04:36 PM
It also depends whether or not a safety collar has been installed. This will keep the chain from going totally slack, and a many istall them as added insurance since it prevents the chain from jumping teeth on the timing sprockets.
Mine had the collars and when I did the upgrade to Carerra tensioners, I found that one had failed. There was added mechanical noise, but it didn't sound like a chain scraping or dragging. More like a loud, erratic rattle. After the upgrade, mechanical noise went way down, and all the noises are constant rather than erratic.
1978 911sc Targa (Sold )
2005 BMW X5 3.0i
2000 BMW 528iT (5 spd, sport)
2000 BMW 323Ci conv. (4 sale)
1987 Corvette Callaway Twin-Turbo Conv
Old 05-12-2005, 04:42 PM
bigchillcar's Avatar
good one, pete..i needed a smile tonight..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-13-2005, 01:15 AM
