Bird. It's the word...
Fishcop's Avatar
Rear Wheel Bearing Question
I'm going to replace my rear wheel bearings, but I'm a bit confused with all the various rear bearing configurations and "inner and outer" bearings...
1969 - Steel trailing arms... Is it just one bearing in the trailing arm or two?
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-09-2005, 04:26 AM
Driver8's Avatar
John,
There is only one rear bearing per side, it requires a special tool for removal and instalation. If you do a search there are some who have fabricated their own tool for this job with bits and pieces purchased from Home Depot.
A
Old 05-09-2005, 06:07 AM
Zeke's Avatar
Pretty much the same thing as a 914 bearing job. At least there is s good article in the tech section for 914s. We don't seem to ever get one for 911s, both early and the later ones, which I think are a different deal.
You should be able to follow the 914 directions and do fine. The cheap version of the tool is explained there too.
Old 05-09-2005, 08:27 AM
911S77's Avatar
Hi, sorry for hijacking...
Does anybody know the SKF manufacturer exact serial number of the rear bearing, or its specs? There's SKF's dealer near my place and I want to order the bearings from them directly. (for some reasons I can't do it from Pelican right now ).
Best regards
/Jack 911S'77
Old 05-09-2005, 08:39 AM
Todd Simpson's Avatar
Yep, one bearing per side. Here's another article that may help.
http://vista.pca.org/sch/tech_articles/rear_bearing_911/911_wheel_bearing.htm
IIRC the archives have a few pretty good posts with pictures as well.
Old 05-09-2005, 08:44 AM
Fishcop's Avatar
Terrific, thankyou!
John Forcier
Old 05-09-2005, 04:43 PM
