Bandwidth AbUser
Last time I checked with Pelican Parts, these were no longer available. Anyone have a recommendation for where I can source one of these hoses (#43 at the top of this figure)?
p/n 999.180.029.50 Thanks!
Jim R. Last edited by Jim Richards; 05-08-2005 at 04:30 PM.. |
Jim,
I belive that hose is just a cloth covered rubber hose of a standard size, can't tell you what size, but it's a standard hose, nothing special. Hit your local shop and they should be able to cut you a small length of it. That's what I did. Pelican should have them too, but I can't seem to find the bulk hose/line.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Jim,
Try part number 999.180.082.50 for the actual part (11 x 17.5 x 60). and 999.180.029.50 for the 11 mm hose by the meter. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Bandwidth AbUser
Thanks guys!
Jim R. |
GAFB
Jim if worse comes to worst, give me a ring. I've got an as-new one with ... maybe 50 miles on it?? All yours if you can't find a new one.
Won't be needing it anymore, as Henry Schmidt is converting my pump to an independent oil supply while he's rebuilding and recurving it.
Several BMWs |
Bandwidth AbUser
Thanks Dave! I appreciate the offer.
Jim R. |
