-   -   '83 SC A/C problem (http://forums.pelicanparts.com/porsche-911-technical-forum/220476-83-sc-c-problem.html)
glenndeweirdt 05-08-2005 03:16 PM
'83 SC A/C problem
It is ouir first 80 plus degree day in Chi-town and I turned on my A/C....Nothin. Ran fine a few weeks ago when I uncovered the car for spring. Had refrigerant topped last summer.
No click from compessor clutch
No blower at all
checked fuse-OK
Checked voltage at A/C evaporator blower motor-voltage .46(?)
How do you check voltage at compressor clutch? Is the compressor clutch slaved to the evaporator blower motor so the compressor does not engage?
I suspect the evaporator blower motor. I assume the refrigerant connections must be opened- ergo let a trained pro take care of it, right?
Any other possibilities?
scottb 05-08-2005 09:21 PM
Is the system still stock? If not, then it might have a high/low pressure cut-off switch. If it does, and if you have a leak in your system, the switch will prevent juice from getting to the clutch.
bit 05-08-2005 11:20 PM
Hi Glenn,
Did you also check the relay in the front?
.Steven
JackT 05-09-2005 05:10 AM
Mine does the same thing when the freon is low.
ruf-porsche 05-09-2005 05:35 AM
Check the relay in the smuggler box, for a cheap fix go to rack shack and purchase an automotive relay. For a more expensive fix order a new relay from Porsche or our host. Unlrss they have NOS (new old stock) the new Porsche packaged relays are made in CHINA.
Yes it was a nice weekend in Chi-town. Did some quick maintenance on my 82SC Targa. Drain and replaced the oil, and went for a drive with the A/C on.
