glenndeweirdt's Avatar
'83 SC A/C problem
It is ouir first 80 plus degree day in Chi-town and I turned on my A/C....Nothin. Ran fine a few weeks ago when I uncovered the car for spring. Had refrigerant topped last summer.
No click from compessor clutch
No blower at all
checked fuse-OK
Checked voltage at A/C evaporator blower motor-voltage .46(?)
How do you check voltage at compressor clutch? Is the compressor clutch slaved to the evaporator blower motor so the compressor does not engage?
I suspect the evaporator blower motor. I assume the refrigerant connections must be opened- ergo let a trained pro take care of it, right?
Any other possibilities?
PCA National, BMW Club, SCCA HPDE Instructor. MSF Level 2
'23 BMW 540 iX (wife's driver)
'14 Cayenne Diesel DD and tow vehicle
'16 GT4
'22 911 Date night vehicle
Old 05-08-2005, 03:16 PM
scottb's Avatar
Is the system still stock? If not, then it might have a high/low pressure cut-off switch. If it does, and if you have a leak in your system, the switch will prevent juice from getting to the clutch.
1984 Targa
Old 05-08-2005, 09:21 PM
bit bit is offline
bit's Avatar
Hi Glenn,
Did you also check the relay in the front?
.Steven
1980 911SC
Old 05-08-2005, 11:20 PM
Mine does the same thing when the freon is low.
Old 05-09-2005, 05:10 AM
ruf-porsche's Avatar
Check the relay in the smuggler box, for a cheap fix go to rack shack and purchase an automotive relay. For a more expensive fix order a new relay from Porsche or our host. Unlrss they have NOS (new old stock) the new Porsche packaged relays are made in CHINA.
Yes it was a nice weekend in Chi-town. Did some quick maintenance on my 82SC Targa. Drain and replaced the oil, and went for a drive with the A/C on.
Old 05-09-2005, 05:35 AM
