1989 Speedometer not working?
1989 911 - Speedometer not working at all
I took my car out last Sunday and the speedometer is not working at all. It worked fine the last time I drove it a few weeks ago. When I turn the key on, the needle just barely moves a hair and then stays at 0 MPH. Any ideas? Is the sensor somewhere on the trans? Aside from a loose connection, is there anything I should check? How do I diagnose the sensor, or should I just buy an new one and try it out? Thanks! Stephen |
If the car was park for a long period, voltage drop could cause the speedometer acting up strange, I have the same problem and wasted the money on speedo sender until I found out the voltage issue, try to drive your car for at least 30 miles for full charge and see if the problem may fix by itself
Good luck
911 1987 Triple Black Cab Turbo Look >> weekend car SPF MK III Shelby Cobra 427 550HP >> thrill for speed BMW 88 635CSi daily drive BMW 87 325i use for rainning day (donation) Benz 06 E350 use for pick-up kid on car pool day |
could be linked to the trip meter-my speedo stoped working when i reset the trip meter a few months ago-try gently resetting it,it worked for me.
88 targa gone but not forgotten. 91 c4 coupe |
Thanks for the tips guys. I will try them out and report back.
Stephen |
