Question HELP! How do I run a new fuel line???
On my 74 the fuel line is damaged inside the tunnel so I need to run a new line. I'm running a new 1/2" ID fuel line from the tank to the fuel pump which is above the rear driver side swing arm. So far I have run the line from the tank thru the firewall and.....and this is where I run into the problems. I've been wrestling around with her for the last few hours trying to get the line down the tunnel. I run into too much resistance just past the e-brake if I run it on the passenger side of the tunnel, and if I run it down the driver’s side of the tunnel it interferes with the throttle line. I can't get it down the original channel which is in the upper driver side.
What do you guys do? Do you run it beside the tunnel inside the car? I could do this as I have removed the complete interior. I was going to get a hole saw and put a 1" hole in the side of the tunnel at the front and rear of the tunnel and run the line inside the car. What do you think? What would you do.
Damn this little project of mine gets frustrating at times...
Old 05-23-2005, 09:47 PM
bump
What is legal for racing?
Old 05-24-2005, 09:33 AM
For safety if I referred to NHRA rules
"Fuel gauge lines in the driver compartment must be steel-braided with steel fittings."
Maybe that is what I’ll do.
Old 05-24-2005, 10:27 AM
DW SD's Avatar
Can you attach it to the old one and pull it through? 1/2" is pretty large. Stock lines are 8mm OD, which is just under 1/3" (at least for some years). -6 is all you need if you go to braided stainless. That is less than 1/2".
There are many threads, all of which say this is a *****.
1971 RSR - interpretation
Old 05-24-2005, 10:52 AM
Is your car CIS? I pulled two 6AN braided hoses (big) through my '75's tunnel without much problem, but maybe the tunnel is slightly different on yours.
What worked for me was a metal "fish" that's used to pull wire through conduit. I ran the lines on the right-hand side of the tunnel.
Old 05-24-2005, 11:27 AM
No it isn't CIS, I'm running a set of webbers on a 3.0. Yes i thought about the fish tape idea to help run the line hhhhmmmm
No The old line is pretty much stuck in place….
Maybe the 1/2" is a little over kill....
Old 05-24-2005, 11:42 AM
Does anyone know the conversion of 'an' to inches? I'm not familiar with this unit. I've been buying my line by inches ID
Old 05-24-2005, 11:55 AM
Slumlord
Porsche_monkey's Avatar
I ran steel tube on the bottom of my car.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-24-2005, 12:00 PM
Mike Bonkalski's Avatar
AN-6 is 6/16th's of an inch IIRC.
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 05-24-2005, 12:11 PM
Thanks Mike...
PBH, I'm a little nervous about running it below the car as the fuel line would be the lowest point and the first to hit if I were ever too bottom out....but that would sure make it easier...
Old 05-24-2005, 12:40 PM
Slumlord
Yea, I'd rather have leak inside my car. There are lots of things lower, you'd have to bottom out the center of the pan.
84 Cab - sold!
Old 05-24-2005, 12:51 PM
len911's Avatar
Do a search for "tunnel" I posted extensive pictures of the inside of the tunnel. Should give you an idea of where it is hanging... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 05-24-2005, 03:07 PM
