-   -   Source for A/C lines in bulk near L.A.? (http://forums.pelicanparts.com/porsche-911-technical-forum/220998-source-c-lines-bulk-near-l.html)
Jared at Pelican Parts 05-11-2005 01:37 PM
Im looking into the costs for doing my whole A/C system with new hoses and was wondering if anyone knows a good source for A/C lines in bulk near los Angeles
scottb 05-11-2005 01:50 PM
I think many auto parts houses carry bulk hose. Also, there's a company in Arizona (the name escapes me at the moment) that will sell you the correct bulk hose in the proper lengths. Also, contact HughR here on the board. He had hoses made up locally and might be able to give you a source for bulk hose.
When it comes time to put the ends on them, I've used a guy at California Tube & Hose (or Hose & Tube) in the Northridge/Reseda area. He's really good, and reasonably priced.
I bought my hoses from Griffiths, and paid WAY too much. You might consider www.rennaire.com. Ron Maxwell is now making up hoses and he's selling the entire kit for $369. At that price, it might make sense not to have to hassle with bulk hose and then having fittings put on them. Ron's a good guy!
Good luck. Let us know what you do.
da911enginear 05-17-2005 06:38 AM
I've been trying to "negotiate" with Griffiths on a system since last summer. Though they have been pretty firm ( I won't say stubborn) on their pricing, they have been really helpful, explaining the pro's and cons' of various approaches, no hard selling but very helpful.
I asked him if he would simply sell me the rear fender condenser without hoses and he said the reason they sell the package with hoses is because two hoses need to be changed to connect the system in series with the stock condensers, and since the car has nearly 40 some feet of hose you might as well replace them all since the two underneath the car usually crushed by lift pads.
What I'm negotiating is the condenser with fan attached, mounting brackets attached, vibration mounts and hardware (apparently he is using all stainless steel brackets and nuts and bolts), stone guard, electrical wiring (something about a relay and fuse) and installation instructions, the two necessary hoses in the new barrier stuff to connect the thing. He said I should install a high low pressure switch? which they build into the a new hose between the compressor and condenser, I told them I'd wait on that. And they usually include a new drier. I said I was gonna try the Pro Cooler thing and asked them if it would work with their system. They said they never needed to use it but it could tie in easily. They also have some type of improved evaporator gasket kit that comes with it the package. I told him I don't want to replace my evap. They said its up to me if I want to replace it but they do suggest that I remove they evap to clean it, so what the heck the gasket kit is included.
I told him up front that I read the boards and none of us want to shell out $2k just yet. He said he understood and they were developing a basic kit for us budget minded drivers. It looks like they have a new condenser design, serpentine, and that will be what I get. I'm shooting for under $1,000.00, after reading all the posts about hacking front fenders for the C2 condenser and all the running around I figure $1k is worth it for a bolt on system that works.
scottb 05-17-2005 06:56 AM
$1,000 is REALLY spendy. If you're handy you can probably do the whole project for half of that. Charlie is a very knowledgeable guy, but he is very expensive.
Here's a little something to whet your appetite to build your own set-up for the rear wheel area. This will fit in front of the left rear wheel.
http://forums.pelicanparts.com/uploa...1116338103.jpg
If you're thinking about putting one behind the rear wheel, do a search here on the board. Someone (I forget who) recently fabbed up his own for a LOT less money than the Griffiths unit.
Good luck!
brcorp 05-17-2005 07:22 AM
da911enginear,
Follow this thread for a cheap yet equally effective alternative to Griffiths's condenser.
http://forums.pelicanparts.com/showthread.php?s=&threadid=176468&highlight=conden ser+dimensions
Also, Scottb is correct in pointing you torward Rennaire for the hoses, fr the price, quality and service you can't beat Ron.
scottb 05-17-2005 07:24 AM
And Bill's too modest to say that he did a great job on his rear fender condenser!
brcorp 05-17-2005 07:45 AM
No, I'm not. I did a fine job!
Mysterytrain 05-17-2005 06:21 PM
hey, Bill..Did I miss something? SOunds like you got your system up and running. How about a report on the results and 'if I where to do it again"..thanks
jdowty3 05-18-2005 04:30 AM
Jared, call a few local AC or brake shops and find out who they use for hoses.
da911enginear 05-19-2005 07:25 AM
Griffiths Kuehl System
Interesting condenser you got there. I thought about designing something myself, giving this thing a lot of thought and this is what I came up with.
1) There are only so many hours in the day and though I would enjoy enginearing or copying someone's idea, frankly I would rather be driving my car than spending time figuring out how to copy Griffiths system. I just want a reliable bolt on system that works.
2) I can find lots of different condensers on the web I think I can fit in there, and god help us if we need to go the Ebayer route, but talkin with Charlie I realized they really got this down pat. After reading their customer comments I came up with my own questions and talked with him for nearly a half hour. Apparently they have redesigned the rear condenser and made many improvements. They use to use a tubin fin or something like that and now it is serpentine. I know I can rig up some brackets but looking at their set up I wont' have to fool around, the brackets are stainless too which I kinda like since I don't want anything rustin out.
3) Yeah, the Griffiths system is more expensive then making my own, but what the heck, it is a Porsche!
I don't want to put any cheap crap in my car that looks like a hack job. I want a system that bolts in and blows cold and I someone to call if I run into a problem.
4) I checked out hose price thing and talked to a local guy who can make them up for me. But I gotta get lengths and something about fitting types. Again, I dont' have time to drive back and forth. I just want to bolt the sucker on and cruise.
5) I looked at the Renn something evaporator, it looks kinda funky in the pictures compared to the Griffiths unit.
Yeah its alot cheaper but I think the Griffiths unit is suppose to have more coils or more surface area.
Bottom line, I might be able to save $500.00 or maybe more hacking together something on my own or usein what you got here but my time is more valuable.
I'll stick around and check out anything new you got but Summer's here guys, time to chill.
scottb 05-19-2005 07:36 AM
The Rennaire stuff looks every bit as good as Griffiths, and at a much lower price. Charlie's stuff is first rate, but expensive. For $369, the Rennaire hose kit is a great deal. Why mess with having a local shop "hack" something together when, for a reasonable price, you can buy everything pre-cut to fit the car from a company that deals almost exclusively with the 911? I thought the Rennaire evaporator looked every bit as good as Griffiths at, again, a lower price. It wouldn't surprise me that they both source it from the same vendor.
It's your money, but this is my $.02. :D
89turbocabmike 05-19-2005 07:52 AM
Jared, try www.ackits.com they're in arizona. bulk hose is $1.71 ft in either standard or reduced-size barrier hose. They also have a great a/c tech forum.
da911enginear 05-19-2005 05:40 PM
I've looked at Renn evap unit on their site, counted their coils and compared it to Griffiths unit on their site. The Griffiths looks like it has more coils and looks thicker. I called Griffiths and asked him the difference. He said he prefers not to comment others stuff, good or bad. But he did tell me about their unit, how it was developed. How many they have sold. What cars are running them, warranty, how to install. It sounds like they know their stuff. He said they are in their 3rd change with improvements and the latest one they got puts out the most btu's per square inch or something. Anyway it sounds like they did not not dream this stuff up overnight. No heavy sales pitch. Just answered my questions and made some good suggestions.... and he did not send me a bill (ha ha). Bottom line, though the Renn unit is "cheaper" in price, the Griffiths unit looks solid and bigger. Bigger is better and it means I can get more cold air.
Yeah I could probably save a couple bucks buying the hoses from Renn. Or borrowing a crimper and getting hose and such on (choke) Ebayer (You can always find something cheaper somewhere else.) Then I could get the other stuff from Griffith. But then you end up buying a little here and a little there, getting this to match that, calling this guy, paying this credit card, etc. I'd rather get one package from one place that I know works, something turnkey, bolt it in and go onto something else.
And I thought about the ProCool thing. Sounds really interesting but after reading all the forums it seems that either it works or it does not work. I dont' have the time to screw around with 50/50 chances of something "maybe" working. What I dont' understand is why I don't see that thing installed in new cars. BMW's don't have um. Porsche dont have um. GM, Mercedes, Chrysler .. etc. nobody uses it. If it is suppose to be the the next best thing to pop tops on beer cans you'd think someone would buy the patent or copy it. Heck, if I had a copy on it and it did work I would be retired and let someone else work on my car. I love the idea of recovering wasted energy but not my own.
I checked out a buddies car yesterday that has all the Griffiths stuff in it. He said he bought it as one package and was gonna have someone install it all, but after reading the instructions he figured he could do it himself. I asked him how hard it was and he said the hoses take the longest to install. I asked about the ones go in through the engine compartment and he said it looked hard but only took a minute to get them through. He showed me, its nothing. Yeah, he layed out some good bucks but I've seen more money wasted on stereo systems that sound like junk. Those rear condensers are top quality (nothing like the stuff on the links here) and the mounts were perfect, the thing looks like it came out of the factory. His 911 was blowin cold and it was mid 90's hot and humid in a black on black. With the two of us in the car he had to turn down the thermostat and the fan. He's got the really neat fan speed control that Griffit makes, any speed you want, and he's got the vents too.
So I'm going with good standard engineering practice on this one, even though you guys look like you are having fun with this stuff. Watch out, you may have Walmart knocking at your door chasing your ideas.
If it works don't mess with it, and, don't try to re-invent the wheel. Griffit has it all worked out. I'm sold.
I enjoy trying to makes things better and if I can find a less expensive (not cheaper) way then I'll go for it. But when you see this stuff it makes you wonder why bothter. In the mean time I can think of other places to save bucks, like on "no stereo", who needs one when you got a nice sounding exhaust!
Hugh R 05-19-2005 06:06 PM
Jared
Go to Lucas Auto Air Conditioning in Van Nuys. 14155 Oxnard Street. (818) 782-3501. If your going to be adding a subcooler (procooler) you'll need extra condensors to get rid of the waste heat. Lucas can custom make the hoses for you, and they're about 2/3 the cost of going to a NAPA dealer to have them made. I made a Jim Sims subcooler for about $25 plus two custom hoses one from the R/D to the subcooler, and another from the evaporator to the subcooler. You'll also be using two different sizes of hose #6 and #8 if I remember correctly.
scottb 05-19-2005 06:30 PM
I'm glad you've got the cash to be sold on Griffith's stuff. As I've said, it's top notch, but spendy. Most of us on the board like to try to save a few bucks with the same or better results. A good example is Don Plumley's effort at building a center vent. Griffiths gets $150. I think Don spent about $20 for the parts, and invested a few hours of his time.
My car is a Targa (no insulation in the roof). I installed a front left condenser/fan assembly, a ProCooler and Griffiths hoses. I sourced a rebuilt Nippondenso compressor from a local rebuilder. My car blows mid-to-high-30s in 90+ degree California weather. I couldn't be happier.
By the way, my Giffiths' hoses did not fit perfectly. If I had my own crimping equipment, I might have been cutting and putting new ends on. But, since you're sold, good luck!
da911enginear 05-19-2005 07:37 PM
scott b, I sense in all your posts that you are a walmart shopper, maybe you should go back to griffit and ask them for a refund, you know like the walmart porsche guy in florida that advertises he'll beat any price. Like I said I prefer to research it, find the median and go for it, lifes to short to complain. I bought their Kuehl vent for $139.00 this year, same price they quoted me two years ago and same price tweeks sells it for. I guess he knew you had deep pockets
flyin wirly birds.
I like this idea Jared has about building an after cooler to recover cold evap outlet gas. My friends outlet pipe on the Griffiths sytsem was basically frosted knee deep. I'll have to catch up with Jared on this approach.
bigchillcar 05-19-2005 07:56 PM
thanks for the cool post, mr. griffith..! ;)
ryan
scottb 05-19-2005 08:12 PM
Let's see...I drive a Lexus, have an Acura as my spare car, and have a Porsche to drive on the weekends. I live in a gated community, and fly my own helicopter as a hobby. Yup, Mr. Enginear (sp), you've got me pegged perfectly.
My 84-year-old Dad taught me long ago that "anybody can get a single scoop of ice cream for a nickel, but it's the smart ones who get a double for that price." Enjoy your single scoop!
bigchillcar 05-19-2005 10:58 PM
lol...late at night...i live for this stuff. touche boys! just let me know the FINAL VERDICT on the right way to do the a/c..i'm in the same boat..wanting barrier hoses, unsure of value of procooler, but still listening, interested in serpentine condenser..have a b.s. in chemistry, but i can't tell you whether propane, brisbane or xylocaine will explode in my car, but may as well 'run with the r-12 that keeps brungin' me'..somebody let me know. i gotta run now..wal mart is good to go at about 1 am...
ryan
89turbocabmike 05-20-2005 12:05 AM
Isn't this too "Walmart" for you?
I don't usually get involved, but let me say da911enginear that Scottb is a very helpful member of this board I don't take kindly to your random punches. We're all Porsche guys here, be nice........you just got here!(7 posts):)
