-   -   Speedometer light replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/221227-speedometer-light-replacement.html)
Anthonycanada 05-13-2005 12:16 AM
How the heck do you replace the speedometer light on a 87-911?
I tried tugging on the spring loaded red plugs from the back but couldn't get them out!
Can some one please HELP.
Formerly Steve Wilkinson 05-13-2005 05:47 AM
Pull harder. Use pliers. Soak the socket with penetrant. It's stuck, that's all.
Stephan
porschenut 05-13-2005 06:50 AM
If they're spring loaded, you probably have to push in and turn in order to free them. Just like a turn signal bulb.
Formerly Steve Wilkinson 05-13-2005 06:55 AM
I don't think so...mine just pull straight out.
Stephan
RoninLB 05-13-2005 08:05 AM
it's a friction fit.
Anthonycanada 05-13-2005 08:03 PM
Thanks guys. I had to pry the lip to nudge the light socket loose.
Figure I should try to change the bulbs since the displays are a bit dim.
Anthony
Pat Crellin 05-13-2005 08:42 PM
let us know how that goes....I need to do that.
Formerly Steve Wilkinson 05-13-2005 08:49 PM
Changing the bulbs won't help. All our displays are dim.
Stephan
Geronimo '74 05-14-2005 08:59 AM
"Changing the bulbs won't help. All our displays are dim."
Hahahaha, very true, and funny
Anthonycanada 07-14-2005 01:01 AM
Finally got around to replace the light bulbs. It does look a bit brighter.... although I don't think it is worth the trouble unless you happen to have the guages pulled out.
I had to replace the steering column cover so I decided to replace the bulbs in the techometer.
