Angry Speedometer light replacement
How the heck do you replace the speedometer light on a 87-911?
I tried tugging on the spring loaded red plugs from the back but couldn't get them out!
Can some one please HELP.
Old 05-13-2005, 12:16 AM
Pull harder. Use pliers. Soak the socket with penetrant. It's stuck, that's all.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-13-2005, 05:47 AM
Recreational User
porschenut's Avatar
If they're spring loaded, you probably have to push in and turn in order to free them. Just like a turn signal bulb.
Old 05-13-2005, 06:50 AM
I don't think so...mine just pull straight out.
Stephan
Stephan Wilkinson
Old 05-13-2005, 06:55 AM
it's a friction fit.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-13-2005, 08:05 AM
Thanks guys. I had to pry the lip to nudge the light socket loose.
Figure I should try to change the bulbs since the displays are a bit dim.
Anthony
Old 05-13-2005, 08:03 PM
let us know how that goes....I need to do that.
pat
18,000mi a year 84targa
Old 05-13-2005, 08:42 PM
Changing the bulbs won't help. All our displays are dim.
Stephan
Stephan Wilkinson
Old 05-13-2005, 08:49 PM
a.k.a. G-man
Geronimo '74's Avatar
"Changing the bulbs won't help. All our displays are dim."
Hahahaha, very true, and funny
Old 05-14-2005, 08:59 AM
Finally got around to replace the light bulbs. It does look a bit brighter.... although I don't think it is worth the trouble unless you happen to have the guages pulled out.
I had to replace the steering column cover so I decided to replace the bulbs in the techometer.
Old 07-14-2005, 01:01 AM
