Cold Start idle setting
Hi,
On a carrera 3.2, how do i set the idle for when the car starts cold? Is there a screw which you can adjust it with?, or is it more complicated and to do with the fuel injection? or the AFM?
Old 06-03-2005, 02:45 AM
BReyes's Avatar
What is it doing?
Bernard
Old 06-03-2005, 04:16 AM
When the car is started cold, the idle is too low, and it stalls. however if i apply some accelerator, i can sort of "make" it idle, and then drive. When the car warms up, it idles fine.
Old 06-03-2005, 04:55 AM
wow.. this is the first time this forum hasn't been able to help me....
_____________________
'73 RSR Interpretation
Old 06-03-2005, 08:35 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
There is a small yellow cap on the idle screw just below the throttle body. It should be plainly visible from directly behind the car. I'll take a picture and post it in a minute...
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 06-03-2005, 09:34 AM
UFLYICU
ZOA NOM's Avatar
A deep 7mm socket will fit over the yellow cap.
There is a procedure for adjusting the idle. You place a jumper between these terminals and adjust the idle screw for 800 RPM. If adjusted correctly, you should hear no difference in RPM when the jumper is removed.
prc-racing.com
Old 06-03-2005, 10:07 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
I would look for vacuum leaks too. They don't just idle down for nothing and 3.2's intakes have a tendency to pull that gasket in if not tight enough. Get some fuel injector cleaner from you local parts store and spray around the base of the intake. Be carefull around the air intake. If you want to see what you are looking for, spray a little into the air intake and the idle will increase. Vacuum leak causes the idle to decrease.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 06-03-2005, 12:51 PM
Okay thanks alot!
I'll check all of these.
So there is or isn't a separate idle setting for a cold start?
Old 06-03-2005, 08:07 PM
UFLYICU
ZOA NOM's Avatar
No separate setting. The DME controls the idle, and will ignore the O2 sensor for the first minute or so until the motor warms up a bit.
prc-racing.com
Old 06-03-2005, 08:23 PM
so if it idles fine when warm, could the idle setting not be the problem?
Old 06-03-2005, 08:40 PM
Sports Purpose 911 Driver
mjshira's Avatar
I would be careful in messing with that, the DME should be able to handle the adjustment between cold and warm.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 06-03-2005, 08:52 PM
UFLYICU
ZOA NOM's Avatar
The idle adjustment will affect both cold and warm idle. If your car is idling normally when warm, then I would look at your Idle Control Valve (ICV), which will vary the engine speed based on a varying signal from the DME. During warm-up, the DME sends a programmed signal to the Valve, and ignores the O2 Sensor. Once warm, the O2 sensor signal will cause the DME to vary the reference to the ICV.
prc-racing.com
Old 06-03-2005, 09:21 PM
OK, so where is the ICV located?
Old 06-03-2005, 10:06 PM
DonMo's Avatar
Check the first picuture above, the component right below the idle adjustment screw is the ICV, it has an electrical connection on the left and two black hoses into it top and bottom. I would take it off and clean it with fuel injection or carb cleaner (inside). It should rattle easily when shaken.
DonMo
Columbia, SC
"Go Hokies"
Old 06-04-2005, 02:21 AM
UFLYICU
ZOA NOM's Avatar
Red arrow is the ICV valve. It can get gunked up and not operate smoothly. Shoot some carb cleaner into the valve and work it back and forth. Also, it should hum slightly when the motor is off and the ignition key is turned on.
prc-racing.com
Old 06-04-2005, 08:04 AM
alright.. will do!
Thanks alot
Old 06-04-2005, 07:25 PM
