abit off center
cgarr's Avatar
(Restrictors) Best $8.00 upgrade yet for me!
FYI Just tossed in some oil restrictors in my 86 3.2 Orginal oil pressure was not too bad, around 1 bar at idle hot and 3.5 going down the road but wanted to try it. Hot idle is at just over 2 bars and 4.5 on the h-way, but what I really like is how my oil tank stays full and my crank case is dry, well not full of oil...
Craig
Old 05-13-2005, 04:50 PM
Air Medal or two
afterburn 549's Avatar
yep thats been the deal.....put mine in a bout 10000 miles ago and just pulled all the rocker shafts looked at the cams all ok (installed rsr rocker shaft seals) none of the valves were loose so I guess no wear?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-13-2005, 05:31 PM
Maybe installing the restrictors would also help lower oil consumption if it's getting past the guides?
Old 05-13-2005, 11:19 PM
There's an on-going debate over these.
On the one hand, they increase oil pressure....and keep the oil level in the sump tank more constant. I also assume it would increase oil pressure in the oil squirters for the underside of the pistons....so maybe there is an increased cooling effect on the pistons.
The counter argument is that as oil ( flow, altogether) is restricted to the head area....it's particularly this area that needs a lot of oil cooling.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-14-2005, 07:05 AM
KCPSG's Avatar
I also had replaced mine last year, and have noticed a little higher pressure. and I would swear that the engine is running a little cooler than before the swap....might just be me though.
here is a little write up I had found before I did the change
http://www.dietersmotorsports.com/tech/2002/3-2002.htm
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 05-14-2005, 07:14 AM
