-   -   Can't put top down while engine is on - can I change this? (http://forums.pelicanparts.com/porsche-911-technical-forum/221429-cant-put-top-down-while-engine-can-i-change.html)
Bello 05-14-2005 02:20 PM
I have an 88 Cab with an electric top.
The only problem that I have is - that the car has to be OFF in order to raise & low the top.
Can I by-pass this switch so I can lower & raise the top while the car is running. e.g.: at a red light....
If you can - has anyone done this & is it very hard to do.
Is this a 2 wrench job? (Details please)
Thank You
craig001 05-16-2005 05:08 AM
IIRC, do a search on Rennlist on one of the 944 forums. I remember seeing a post on this fix from when I had a 944S2 Cab. The fix should be similar.
