Can't put top down while engine is on - can I change this?
I have an 88 Cab with an electric top.
The only problem that I have is - that the car has to be OFF in order to raise & low the top.
Can I by-pass this switch so I can lower & raise the top while the car is running. e.g.: at a red light....
If you can - has anyone done this & is it very hard to do.
Is this a 2 wrench job? (Details please)
Thank You
Old 05-14-2005, 02:20 PM
IIRC, do a search on Rennlist on one of the 944 forums. I remember seeing a post on this fix from when I had a 944S2 Cab. The fix should be similar.
Old 05-16-2005, 05:08 AM
