-   -   Speedometer: Mechanical to Electronic ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/221444-speedometer-mechanical-electronic.html)
hifeverz 05-14-2005 05:18 PM
REF: '74 911 Speedo Conversion
I have installed late 993(964) electronic gauges on my '74 911. I had the mechanical speedometer and replaced with an electronic (VDO 964)speedo. I purchased a mechanical(cable drive) to electronic signal output device for the new electronic speedo. It is NOT accurate and fluctuates the speed reading.
Has anyone out there done such a conversion successfully, without changing the trans (which has the electronic output drive for the speedo)??
Thanks,
Nz
:confused:
