-   -   Why Are Turbos Unwanted (http://forums.pelicanparts.com/porsche-911-technical-forum/221502-why-turbos-unwanted.html)
dyerkes 05-16-2005 11:56 AM
I owned to na 911's ('77 S Targa and '87 Carrera coupe) before buying my current 1986 911 Turbo (~80K miles). With the exception of having spent more money on HP upgrades (bigger turbo, tial wastegate and intercooler) my other maintenance costs have been about the same. Admitedly the heat generated by the extra horsepower will eventually take a toll and cause you to have to do engine work sooner than an na. But, there is absolutely, positively no sensation like a 911 on boost! As far as lag and throttle response, its like any other CIS vehicle until it hits boost. Boost is like a drug, addicts complain that they can't get enough of it or soon enough. With a few upgrades these older 911 Turbo's are quick to change their responsiveness. The biggest obstacle to overcome is the driver's ability to manage what he has strapped himself/herself into. You have to learn how to manage the beast, and resist the urge to immediately go out and drive it like any other 911...because it just isn't.
I love my former na 911's, but I would never want to be without my boost.
1986 911 Turbo
ficke 05-16-2005 12:21 PM
What I want to know and I think what the original question for this thread is " why do people spend 930 money to have a NA car that will do the same thing" We have all seen the $60.000.00 flared fender cars with the 300 plus HP twin plug engine that is "cammie' or "peaky" instead of "turbo lag" and there is a reason people do it and it is not because they or saving money or can not handle the power and they or not meeting racing regs. I have 930 money in my 67S which makes maybe 170hp but I am doing it for the feel of the SWB high strung engine car that is still to fast for more than 60% on the street. Once again I also want a 930 ( and a fiberglass "76" 308 anda, anda):D
Tom F2 05-16-2005 12:22 PM
Originally posted by Formerly Steve Wilkinson
Opinion: turbos are a crude way to make power, and just as rear-wheel drive and rear/mid-engine are the gold standard, so is natural aspiration. Quicker, more linear and more predictable response. The people I know who have raced various turbocharged Porsche professionally admit that what you do, basically, is drive around the corner and then use the brute force to eat up the straights. Little finesse involved. As I said, purely opinion.
Stephan
Didn't you perform the road test on the Turbo Carrera for Car & Driver in 1976 or 1977? C&D reported a 0-60 time of 4.9 seconds, as I recall, which is still a pretty good time. But, then R&T reported a "badly slipping" clutch in their road test of the same model, which prevented them from bettering the high six second range. Could it be that C&D burned out the clutch on the same road test car before R&T got a crack at it? My 3.0 makes expensive clutch smells if I launch it too quickly.
The problem with all Turbos before '89 is the 4-speed trans. It is a sturdy device, which Porsche probably fitted to the car in order to homologate it for racing. Porsche tried to mask this problem with a massive cast iron clutch in the 3.3 cars, in place of the aluminum clutch in the 3.0 cars. But, the gearing is just hopelessly ill suited for driving around town, no matter what you do. Andial offers an 8:39 ring and pinion, which is supposed to help. John Walker, a frequent contributor to this board, seems to have found a fix in fitting a 915 in his car.
skipdup 05-16-2005 12:54 PM
I drive my '79 930 daily. I've always heard people complain about the 4 speed and in-town driving. However, I have NEVER had the gearing of the car bother me. In fact, in stop-&-go traffic, I prefer the 4 speed - maybe it's due to less gear changing compared to other cars??? Turbo lag in traffic is not an issue, since I'm not trying to get to 60 mph in under 5 seconds and the car can keep up with traffic just fine out of boost... What am I missing?
Also, doesn't the suspension geometry (not just the turbo) affect how the car handles compared to n/a 911? That's what I was told last week while having my suspension tweaked by a well respected Porsche "seter-upper".:)
- Skip
nostatic 05-16-2005 01:04 PM
I see lots of turbo proponents talking about speed, etc, but I don't think any of them answered my question: is it appreciably harder to throttle steer a turbo v. na? I don't give a crap about how fast it is on the street or against an suv...what about on the track? I would love some more hp to have a better chance in the straights, but I don't want to lose any of the fine control in the corners. thoughts from those that know?
thabaer 05-16-2005 01:11 PM
Doesn't anybody remember the Porsche engineer that declared 930s were properly steered using the throttle ?
patkeefe 05-16-2005 01:12 PM
DerickC:
Thanks for the clarification. I was a bit confused on your use of the efficiency term last evening. I agree the benefit of use of simultaneous super and turbochargers is pointless for Porsche applications; really it's best suited for big trucks or stationary equipment which is rev limited to low RPM. I would still imagine that compression regardless of the type of turbomachinery will still produce x amount of heat per specific volume of air compressed. The whole point of the turbo is to increase the volumetric efficiency of the cycle ("how much charge can you pack into the cylinder").
Now, if I can just find a lower output unit and kick up my weak 180 HP to 230 or so, and bring the boost in at 2500 RPM, I'll be happy. If not, then the rebuild will be NA.
Pat
Navaros911 05-16-2005 01:27 PM
No offence skipdup, I think you've got a great car...
But it sounds like you're paying for a turbo without using it (for daily driving). My point exactly...
Makes an excellent track car though.
Nonetheless I'd go for one for daily driving... just 'cause I want to (I'm sure I don't represent the average driver - but then again, who wants to be called average).
nostatic 05-16-2005 01:27 PM
that's how you steer any 911...
Argeo 05-16-2005 01:36 PM
Did anyone mention looks? Maybe it is a silly answer but for us nongear heads, I think it is something we consider.
I like the turbo look but love the look of the impact bumper N/A cars 74-89 ( i think)and really love the 73 RS. Oh, the 993 NA are really nice to look at too.
Honestly I couldn't afford a Turbo but really never wanted one so I guess I am lucky. There all great right down the line:911, 930,928,912,914,944. Heck, I am even starting to like the look of the 996. Can you really go wrong? I don't think so.
My next will be a 914 for sure for it's uniqueness.
Justin R 05-16-2005 01:53 PM
Re: why are people afraid to buy 930s
Originally posted by alwaysflat6s
Well folks
Thank you
air-cool-me 05-16-2005 02:28 PM
wow... so much misinformation.... kinda scary...
I had the opportunity to drive a EFI 3L then my CIS 3L and now my turbo cIS 3L..
well... nostaic... i would say its harder... but... the drop in throttle response from preturbo-baekit seemed about the same amount as EFI- CIS.
(i had a month between the EFI car and the Turbo car... so my memory might be a little off)
so unfortunately for me... CIS and a turbo makes you add an input mid corner and WAIT ever so slightly for a response
But if your not putting it together a 20 year old kit in your backyard.... you can make a Almost lag free system with great drivability.
skipdup 05-16-2005 03:12 PM
I never said it was only a daily driver. :)
5axis 05-16-2005 03:18 PM
escape velocity
yep,nobody would want one of these :rolleyes:
http://forums.pelicanparts.com/uploa...1061449904.jpg
it's not just a car, it's my life sucks escape pod!
david 89 turbo cab
930addict 05-16-2005 03:53 PM
Yeah I don't know who would want one of these either!
http://forums.pelicanparts.com/uploa...1116283928.jpg
Daily driver and occasional therepy session.
:D
911 heathen 05-16-2005 04:57 PM
Apart from my limited budget, I do prefer the NA cars; they look cleaner, have a nicer rear end....
However in terms of performance, both cars have their strengths. For example last weekend my local club did a run and one piece of road was tight and very twisty (but slightly damp).
It was the kind of road that has you in 2nd or 3rd at 5-6000rpm; I was able to literally blow the following 930 away.
I could not think of a better car than mine in such conditions.
But back on the h/way, man he was gone........
http://forums.pelicanparts.com/uploa...1116287849.jpg
fastpat 05-16-2005 05:24 PM
:D
Ummm, pleasingly plump.http://www.pelicanparts.com/support/smileys/wat1.gif
fastpat 05-16-2005 05:33 PM
Of course, I rather like this one, however, she belongs to another. Sigh;)
http://images6.fotki.com/v162/photos...SCN1636-vi.jpg
trader220 05-16-2005 05:34 PM
I'd rather have the speedster too,well maybe, even though they are not turbo.
350HP930 05-16-2005 06:29 PM
I prefer hard tops. The way I drive I want the security of a solid structure around my head.
