Re: Re: When to rebuild calipers?
I respect your opinion, but on this point I disagree. Lots of folks do not know, if or when their calipers were ever rebuilt. Are you saying "its time" just because you do not know?! Rebuild kits for my Turbo Look car are $70 per caliper from our sponsor. Apparently, you are in a much higher tax bracket than I :-) If your car exhibits any of the traits of dragging rotors, and you can confirm, then "its time" |
Nine9six, it's not possible to disagree with me and still be correct. (Winking face goes here). Even at $70 per, if the vehicle were 15+ years old I would rebuild its calipers. And the probability that my tax bracket is above yours can be characterized as "remote."
There are several things I have noticed that mechanics tend to do fairly quickly to older, used cars they buy. Shift bushings, for example. New clutch cable is not a bad idea. Tranny fluid change. Caliper rebuild. |
when i bought my SC. i was thinking along the lines with supe. i was about to order rebuild kits, when i talked to the PO. (we are friends). turned out that he installed new rear calipers and had the fronts rebuilt. saved me a few bucks and some time. but i would have done it for "clean slate" piece of mind. job is easy enough. i even have a dedicated bike pump for the job.
every caliper i have popped apart, has had (some) sediment in them. what is that stuff? sand?. flushing gets that out too? |
OK, which calipers need to be rebuilt how often?
S type with Al pistons? vs. others w/o the corroding Al pistons?? If you guys reach an informed consensus, or even different but defined positions, add it to the long term maint. thread... And where is Dr. Brakeburg on all this? |
Hey BD
Rebuild them when they look like this: (caused by Watkins Glen) http://forums.pelicanparts.com/uploa...1113182118.jpg |
I am rebuilding them just having a little trouble sourcing the rear caliper rebuild kits as you may have seen in my other thread.
http://forums.pelicanparts.com/porsche-911-technical-forum/221885-1968-911l-911s-rear-caliper-kits-nla.html |
well I somewhat agree w/superman..however I think that rebuilding you calipers every year is quite excessive, I did decide to do the caliper rebuild just about 6 weeks ago when I was installing new rotors and pads and lines...it was just a little more to go on and do the rebuild too.
And now I have piece of mind since I didn't have any paperwork showing when or if it had been done before. I might have thouhgt twice about it if they were turbo rebuild kits. (more pricey) but I think I still would do it, it just gives you a good base line to start w/. The job is probably a 1 on a scale of 1 - 10...it really is not that difficult if you are even just the slightest bit mechanically inclined. otherwise another tell tale sign for a rebuild is ...are the leaking??? or not releasing.? |
| All times are GMT -8. The time now is 05:59 AM. |
