racemor's Avatar
Engine tin paint - high temp?
As part of my motor rebuild I'm doing some detailing. I've decided on paint instead of powdercoating for the enigine tin to allow touch up later on. But wondering if I need to use high temperature paint? I know we're not talking about exhaust system type of temperatures, but there is a good bit of heat soaking off of the motor into these pieces. Any previous experiences you guys can share?
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 05-18-2005, 10:48 AM
Por-15 is tough and can deal with clunking of ratchets.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-18-2005, 10:59 AM
Friend of Warren
I used POR15 on mine, but any decent paint is going to work just fine.
Kurt V
Old 05-18-2005, 11:32 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Wurth high temp satin black.. you can get it through pelican
Will program for food
ghnat's Avatar
I got mine powder coated
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 05-18-2005, 11:34 AM
If you bead blast them, any good paint will stick. I used a high temp semi gloss black from AutoZone.
Old 05-18-2005, 11:45 AM
randywebb's Avatar
if you are cheap & lazy get some BBQ black at any store
the Wurth noted above will be a lot better quality and match
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-18-2005, 11:52 AM
Wood Magician
Powdercoated for sure, by the time you buy decent paint and do all the labor to paint it (hours & hours) you could have just dropped it off and had it powdercoated for about $60.00 - $100.00. Price varies ofcourse depending on where you live and from place to place, I live in an area that has at least 15 different powdercoaters so there is competition to keep price low and quality high.
You just cant beat the durability of powdercoating. Unless you are doing a complete to the detail restoration there is no reason to paint the tin
just my 2cents- Jeff
Old 05-18-2005, 11:53 AM
randywebb's Avatar
That might make him change his decision... I powdercoated mine.
But it will never look exactly like stock.
Old 05-18-2005, 01:28 PM
racemor's Avatar
Thanks guys, all the parts are being blasted so I'll have nice, clean surfaces. I'll go with the Wurth high temp.
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 05-18-2005, 01:31 PM
Crusty Conservative
silverc4s's Avatar
Yep, what Brian & others said. the first time that gas gets on your newly painted tin, you will be saying, 'why the he!! didn't I powdercoat this stuff?"
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 05-18-2005, 02:21 PM
