Fabspeed or Dansk?
I'm trying to make a final decision on what I want to do for my exhaust system on my 3.2 and I narrowed it down to three options:
1. Stock heat exchangers, Fabspeed cat bypass/euro premuffler into a muffler bypass pipe 2. Stock heat exchangers, Fabspeed cat bypass/euro premuffler into a dansk 28 lb sport muffler 3. George's headers into a two in, two out Dansk 28 lb sport muffler Is it really true that Fabspeed (#1) will make more power than a full header system(#3)? That is what was said on the fabspeed website, but it could be biased. I'm looking for the one that makes the most power without being too obtrusively loud, and without resonance, although i can put up with some noise. BTW, which would be the lightest system? Thanks.. Last edited by 84Carrera911; 04-28-2005 at 10:12 PM.. |
Automotive Monomaniac
It sounds like all you are using (of Fabspeed) in #1 is their cat bypass... correct?
I can't see how that alone will make more power than a full header system. I just ordered a dual outlet Fabspeed muffler for my 930 (one flowthrough and one dump pipe), but I don't expect much in the way of horsepower as my headers will be stock (for now). Do a search on this site, you will find tons of valuable advice ~ pro and con ~ on all systems (and it was one reason I called Fabspeed to talk to someone before I placed my order).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Banned
I have to be honest, I think that Fabspeeds horsepower claims are a bunch of crap.
I e-mailed them and asked about what kind of horsepower I could expect from a cat bypass tube and their muffler on my 82 sc......22HP was their response. OH PLEASE I supose their custom air box will get me another 15hp? Option D) SSIs with a Dansk or Monty muffler. A setup with that has some actual dyno data to back it up. |
Option #5: George's headers + Monty.
Option #6: George's headers + individual Phase 9 silencers. (Coolest IMO, and probably the lightest system)
You are SOOOO right. Creative marketing at its finest.I'd agree; the SSI/Monty combo works very well and unlike the Dansk, Monty mufflers are stainless steel INSIDE as well as the outer shell. A quick look around inside with a Borescope shows a big difference in materials and build quality. Just one person's opinion, of course,....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
i have the std exch plus dansk bypass and twin sport muff. it will get you around 10-12 hp (i dynoed mine) with no resonance.
its nice, but if i had the cash i would try a monty.
Rich ![]() '86 coupe "there you are" |
I've got an original Euro Pre on my rebuild and I don't know if it made any difference since I didn't dyno it before the rebuild witht the cat. There's a lot of research in topic if you search. The point being a similar HP increase as a SSI setup if you use a Pre Muff and a single in/dual out setup. There's some kind of graph posted comparing the two. It's similar.
78SC coupe, Silver Metallic |
Schleprock
If sound is a major concern?
I'd go with the cat bypass pipe. And choose a Dansk cat bypass pipe. The Fabspeed unit, while quite nice looking, hasn't fit all that well in the past few years.
Kevin L '86 Carrera "Larry" |
I just put on the Fabspeed Euro Pre muf and dual outlet muffler.
The sound is fantastic !! The power.... I haven't dyno'd the car yet, but the seat of the pants dyno feels good. I paid as much to have the poor fitting muffler installed as I did for the muffler itself ! Very bad customer service !! Chuck |
You might want to read up on the Cat bypass (test pipe) and its HP figures.
If you don't need heat, I'd go with George's headers and Monty muffler. Otherwise, SSIs and Monty.
'82 911SC racecar '05 WRX STi |
MBruns for President
Yeah - if you go with the stock exchangers - then you want a premuffler - not a bypass (straight through pipe) if you have the cash - then the headers are going to give you a little more grunt (torque) but not much hp. Obviously to make all the components work together a tuned Steve Wong chip.
My wrench - only recommends an exhaust change from stock if the cams are changed. Otherwise he states that the bang for buck is pretty low.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Longhoods Unite!
1970 911T -- Neglected, oil burning problem, batman smoke 1974 914 2.0 Weber'd -- new project!! **My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
I have no need for heat, all my ventilation other than the oem exhaust is removed. I'm kind of stuck on the Georges headers, but still need to make a decision on the muffler. From what it sounds like, I think the monty is a little too pricey for me, what is the price anyhow?? My main concern for the muffler is no resonance, as long as its not super loud its fine, and i would prefer it to be pretty light if possible. What are the individual phase 9 silencers?
I purchased mine from Aase: http://www.**************/monm311975si.html $716. Let me know if you need more info, or a sound file or anything.
Arent the monty muff's only single inlet though? Would this work with georges headers?
Sorry I pointed you to the wrong page. The one I pointed you to is single inlet. With SSIs/headers you need one of these:
http://www.**************/por91119.html I have the third one down.
if you don't mind could you post your sound clip?
Here is the car.
Here is the best I can do right now for the muff:
Doesn't want/need a 3.6L
One suggestion: If you stick with your header decistion, don't go overboard on the header diameter (smaller 1 1/2" is better than larger 1 5/8" for street use on a 3.2L IMO) and do some research on the muffler inlet flange diameters from the muffler mfgs. you are considering to make sure they properly mate to the headers.
Ralph |
