In the shop at Pelican
Jared at Pelican Parts's Avatar
What worn components would cause understeer?
So yesterday im getting off the 5 on a nice long 90 degree exit ramp that exits perpendicular to the freeway at a 30 foot elevation change. I hit the apex and the car starts oversteering a bit, certianly not confidence inspiring.
Are there any common worn parts that would cause this?
Suspension is otherwise stock SC
Old 05-18-2005, 11:00 AM
Tire & tire pressures?
Old 05-18-2005, 11:02 AM
tire pressure is ok.. I run a little more in the back than the front..
typically 37/40 front/rear
Old 05-18-2005, 11:10 AM
Senior Member
Superman's Avatar
That's certainly plenty of tire pressure.
One of the most important benefits of autocrossing and DE'ing is the information you get. The surprizes you get. My car oversteers deliciously as I turn corners in street driving. I always always always finish the turn with the throttle and the rear snaps into place. After five years, this still gives me joy at each turn.
I expected this car to oversteer at autocross also. SURPRIZE! At slower speeds and deeper throttle positions (such as at autocross) I have to fight this car around the 180-degree turns. And I mean fight. Working the throttle and the steering wheel, and even the brakes! In second gear, turning sharply around a 180-degree turn at autocross with the throttle open, this car understeers horribly.
But at higher speeds such as you get at DE events, the car is back to oversteering. Don't know if this helps you.
Mocha 1978 911SC. "Coco"
Old 05-18-2005, 11:22 AM
Drop a couple pounds in the rear and see what happens.
(edit - meant to say 'rear')
Old 05-18-2005, 11:24 AM
but would this also have to do with worn sway bar bushings, shocks etc... i plan on renewing all my suspension as soon as i get my new cooler in
Old 05-18-2005, 11:30 AM
drag racing the short bus
dd74's Avatar
Like Thom says, Jared. Mess with tire pressures first.
The Terror of Tiny Town
Old 05-18-2005, 11:39 AM
Somatic Negative Optimist
Gunter's Avatar
Jared Fenton: 37/40 PSI on an SC? What kind of tires and how old are they?
The manual says 29/34. What is your Camber and toe on all four? Castor in front? Good luck with getting the ring-nuts off the external oil thermostat; read the posts on that subject, it's fun!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-18-2005, 12:58 PM
Bridgestone Potenza RE750's about a year old
thanks for offering help
Old 05-18-2005, 01:00 PM
jluetjen's Avatar
Alignment also has a big part to play. Basically you need to know that everything is set-up correctly, otherwise the car's handling will be off.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-18-2005, 01:01 PM
I used to run RE730s I ran 34 front, 36 rear, on 7" & 9" Fuchs. 22mm front torsion bar, 29mm rear, 1/32" front toe, 1/16" rear, -2 degrees front camber, -2.5 rear
Old 05-18-2005, 01:20 PM
Gunter's Avatar
Right on, John, I just did my alignment after the car didn't handle right and have a noticable difference. Of course, before any alignment the mechanical components have to be right: struts, balljoints, bushings etc,
A wild guess isn't going to help.
Just asking what could be wrong without giving details about camber, castor and toe is meaningless.
Old 05-18-2005, 01:29 PM
dd74's Avatar
Yes, alignment was a major factor too, as well corner balancing. I drove at Willow before and after an alignment and corner balance, and the difference was quite noticeable.
Old 05-18-2005, 01:46 PM
How exactly does a corner balance work?
I aswsume you add weight to opposing sides of the car to balance it out?
Old 05-18-2005, 01:51 PM
dd74's Avatar
To me, it's almost voodoo science, but it works. I've seen Tyson do it in action, but could barely follow him. I believe it is counter-weighting from corner to corner, but I know more knowledge about this than mine exists on the board.
What I do know is if I had a choice between spending a bunch on torsion bars, monoballs, bigger sways and stuff and a good corner balance and alignment, I'd opt for the corner balance and alignment. All the rest of it matters little unless you have a good baseto work with first. In fact, you may find you won't need all the other stuff once you do have a corner balance and alignment.
Old 05-18-2005, 02:15 PM
And if you do all the other stuff, you're going to need a corner balance and alignment anyway...
Old 05-18-2005, 02:23 PM
dd74's Avatar
Very true...
Old 05-18-2005, 02:49 PM
B D B D is offline
B D's Avatar
Jared take it to Darren at Westend he charges about $60/HR last time I was in and he transformed my car in just over 3 hours best money I have spent to this day on my car. He will explain everything he does to the car and what he finds. I sat in the drivers seat while he did all the work. He did the alignment, corner balance, set the camber and balanced and rotated the tires. Several board members have used him and would agree it's the best money spent. He is the only one in the shop and the only one to touch your car.
Westend Allignment
Darren #310-808-9233
68 911L
Old 05-18-2005, 03:00 PM
If you drove your car on one wheel, we'll say the left front for the sake of argument, all the weight would be on the left front. If we decided that both front wheels would make for a better handling car we'd want the weight equally distributed from side to side (in general). Tilting the car to the left or right would achieve this. Now we know of course, that it is best to have all four wheels on the ground. Thus we would want the same left to right equality we had in the front for the back. The backs of our cars are heavier than the front, so the left and right rear weight will be a higher amount (someone correct me here if I am wrong, but I believe this is correct) than the front, but approximately equal from side to side. The problem is when we have four wheels and tilt one corner up or down it affects not only the other corner on the same side, but also the corners at the opposite end. Thus one has to go back and forth and get the two fronts as close to their ideal, and equal from side to side, as well as the backs. No, the car won't necessarily end up absolutely perfect, or even have perfectly even ride height, but it can be done to reasonable tolerances on a street vehicle. It's an involved process, and some vehicles come out better than others.
Loose sway bar bushings make a given bar less effective. In general, stiffening rear components, e.g., bigger sway bars (or shorter arm setting) or torsion bars make for more oversteer. Lessening same in the front has a similar effect.
'80 SC
Old 05-18-2005, 03:17 PM
