-   -   sway bar size ??? (http://forums.pelicanparts.com/porsche-911-technical-forum/222099-sway-bar-size.html)
74 clssc 05-18-2005 03:44 PM
sway bar size ???
Don't know if this makes sense, as i was looking the car i noticed that my front sway bars is larger than the rear,is this ok or it must be the other way around? pls inform this ignorant newbie and advance thanks to those who will reply to this post. good
day!!!
by the way here is a photo of my car,finally figured out how to upload pics check it out its free!! http://forums.pelicanparts.com/uploa...1116456141.jpg http://forums.pelicanparts.com/uploa...1116456281.jpg
74 clssc 05-18-2005 04:41 PM
oh it is normal! k i was just wondering coz i see people when they say they have 18/21;21/26;22/27 doesn't that mean F/R , so i thought front has to be always bigger than the rear as far as sway bars if concern.btw thanks Noah for replying back i just kinda got worried and thought that was the reason why my car handles kinda weird!!
Navaros911 05-18-2005 04:46 PM
Noah: Thats contradictory to what I find here http://www.pelicanparts.com/techarticles/911_torsion_bars/911_torsion_bars.htm
I'm not an expert on this, but it looks like one of the sources is wrong.
74 clssc: Nice.... I just like those years.
JP911 05-18-2005 04:46 PM
Those numbers are typically mentioned here in reference to torsion bar sizes, not sway bars. The front torsion bars are smaller in diameter than the rears.
Sumotang 05-18-2005 04:48 PM
are you talking about the sway bar or the torsion bar?
The numbers you just mentioned are torsion bar sizes, I thnik.
The SC's have 19mm Front and 24mm rear from memory. Don't know abou the 77 Carrera.
Others may be able to clarify. Nice car!
dd74 05-18-2005 04:50 PM
Hmmm...those numbers seem a little askew. More like torsion bar #s.
I don't remember what the sway #s are for a '74, but they're nowhere near that high - not even 18.
Anyway, sweet car. Have any shots of the interior? I'm curious about the seats...
74 clssc 05-18-2005 05:56 PM
Wait a minute now i'm really confused, Noah said thats normal, then Sumotang mentioned he has 19/24mm on his SC. Therefore it either big on the rear / smaller front or vice versa and it doesn't matter? does it have a difference handling wise ? sorry this might sound like a stupid question but i really just have no clue on this matter. thanks guys for entertaining my silly questions. btw-dd74 i think i do have pics of the interior!
Sumotang 05-18-2005 05:59 PM
Noah is talking about the sway bar. I am talking about the torsion bar. Dont know much about the sway bar but the rear torsion bar is always larger thatn the front torsion bar.
The torsion bar is like a spring in most cars suspension system. As most of the weight is in the rear for a 911 it makes sense to have a stiffer/larger bar.
74 clssc 05-18-2005 06:04 PM
here some pics of the interior.http://forums.pelicanparts.com/uploa...1116464370.jpg http://forums.pelicanparts.com/uploa...1116464399.jpg http://forums.pelicanparts.com/uploa...1116464437.jpg http://forums.pelicanparts.com/uploa...1116464499.jpg
thats all i have as far as the interior pics , i'll probably take a better picture one of these days!
Sumotang 05-18-2005 06:06 PM
Nice engine bay!!!!!!!!!1
74 clssc 05-18-2005 06:13 PM
sumotang- thats what i thought the rear i would think should be bigger,but in my case i don't know what happpen on this particular car why its the other way around,i even used a dial caliper to measure them so i wouldn't sound so dumb when i post this question.And its 18mm rear and 21 front. what should i do now????is it possible that the previous owner put 'em the other way around or replaced the rear w/ the wrong size?thanks
Sumotang 05-18-2005 06:22 PM
Are you talking about the sway Bar????????
You cant see the torsion bars.
74 clssc 05-18-2005 06:32 PM
yeah sway bars!!! the steel iron made bar that goes to one side of the car to the other w/c passes by the tranny i think or a little farther back,then there is another one in front,isnt that the sway bar ?
Sumotang 05-18-2005 06:56 PM
Yes that is the sway bar. I am talking about torsion bars.
Noah said that was normal to have the front larger than the rear.
dd74 05-18-2005 10:29 PM
So yours must be a 911S, huh? Very cool. And bloody fast! I'm not sure the seats are standard - they were one piece starting in '74. Otherwise, the rest of the interior is very nice.
Hmmm...black engine shroud. Anyone know what that means? Does that mean the S engine, or did Porsche throw whatever color shroud they wanted on the engine at that time. I thought they were all green in '74.
Anyway, about the sway bar size, eh...don't worry about that. Worry instead about the bushings and make sure they're good. Next, align it, corner balance it. Then come Fall, take it to Willow Springs Raceway.
P.S.: you'll need a helmet for Willow. ;)
Steve@Rennsport 05-18-2005 11:40 PM
'74 911's came with 16mm swaybars front & rear as standard. The optional bars were 20mm & 18mm, front & rear.
The 911S & Carrera (175HP) had a green fan shroud; the standard (150 HP) 911's shroud was black.
450knotOffice 05-19-2005 12:58 AM
Don't worry. Your sways are fine.
Stiffer SWAY bars in front relative to the rear help to inhibit oversteer which is what Porsche was trying to do
As for TORSION bars, which can not be seen, they will always be smaller in front than the rear.
