fog lamp relay
Anyone know if there is a factory relay hooked up to the fog lamps? Thanks. How many of you run 80 watts lamp in there using stock wires, and does it help. Thanks. Oh, its an 88 930.
Jeff |
i'm troubleshooting my fogs as well (84 carrera), and, yes there is a relay for them. I believe it is the 5th one from the left. (I have the thick manual for the car, thankfully). I'm pretty sure my relay is shot, because everything else seems fine. Finally getting the courage to troubleshoot electrical things. Good luck.
happy 1984 3.2 customer |
Re: fog lamp relay
Tim
1986 911 Cab 2008 Audi A6 |
Sizzle,
Thanks. I am just thinking about using the low beam GM head lights in the fog llight area somehow to get better llghting for ours cars. I am talking about the small ones for the early 90's pick up trucks. Tim, I don't understand how a slighter fog will bother on comng traffic. It is so low and aim downward a bit. It shouldn't be no brighter then a normal H4 head lights? Not even close to being as bright as some late model car's low beam. They are bright, like the Bimmers. Jeff |
Tim
Tim,
Where abouts are you in Alta. So where do you get to open up the 911? I was up there around Calgary and Edmonton. My cousin told me that the cops are out there and do not speed. They will get you everytime. All I can think of was all the straight roads and the hwy 1 going to BC. What a waste in my big SUV and not the 930. THere were no cars around going to Drumheller(spelling). We don't have open roads like it in LA. Always too many cars. Jeff |
Highway 36, south of Brooks (not far from Drumheller) is usually pretty safe for "opening the throttle". I've also followed welding trucks going north to Ft. McMurray on Hwy 63 in excess of 140 kph. Alberta, home of photo radar, red light cameras, etc etc. Fortunately, the RCMP have not yet started (at least as far as I have seen) using photo radar. Tim
So, if Sizzle is correct, and there IS a relay for the fog lamps, would it be safe to plug in higher wattage bulbs? Do i need to upgrade (thicker) the wiring also?
thanks
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
I am installing a set of Hella fogs, which come with H3 55w and wanted to go to H3 100w.
So I have this same question. I emailed Marcus Sucro and this is his answer. "The formula used to determine current is Watts/Volts = Current. As an example, 55W/12V= 4.58A. Remember that the fog lamp relay supplies both fog lamps so the current is doubled (2 x 4.58 = 9.16A) If you use a bigger bulb the current will go up proportionally. An additional consideration is the current carrying capacity of the wiring harness. This is not the easiest thing to calculate if you don't know the wire gauge. To make a long story short, I think you'll be fine with 100W foglamps and a 20A relay."
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
Thanks man.
