-   -   Tach pegs when key turns on!!! Help? (http://forums.pelicanparts.com/porsche-911-technical-forum/222364-tach-pegs-when-key-turns-help.html)
avendlerdp 05-20-2005 05:01 AM
The title says it all. THe tach pegs out as soon as I turn on the key. Car runs fine. Has anyone seen this before? What to do?
Alex
Kroggers 05-20-2005 05:35 AM
Hi Alex, I have the same problem (intermittently) - if I understand your description correctly. Here is my original request for assistance - http://forums.pelicanparts.com/porsche-911-technical-forum/216113-rpm-mind-its-own.html I never got any reply. If this is the same problem, then let me know if you figure out what is wrong!!!
911AtLast 05-20-2005 07:56 AM
avendlerdp - how old is your car?
My '76 ROW Carrera 3.0 developed this problem this year - tach was occasionally pegging and always erratic - solved the problem immediately by changing the points...
Worth a try (if you have points!) ;)
Warren
