vizail's Avatar
Cleaning and Shinning Aluminum
Just wondering if you Guys have a procedure to clean your Porsche underside aluminum engine Block. I rebuilt my Porsche engine and will like to give the aliminum a shiny look. A Show Car look..!
Sugestions..!
Vic
Old 05-16-2005, 07:37 PM
Haven't done this myself, but I guess alloy wheel cleaner (the foaming type), combined with a small brush should do the trick?
Cheers!
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 05-17-2005, 02:56 AM
vizail's Avatar
Yes thats what I will like to do .. give it a luster or at least a polish....!
Vic
Old 05-17-2005, 05:30 AM
Irrationally exuberant
ChrisBennet's Avatar
The motor I'm building up now had been pressure washed/degreased and left in a shed for a while. As a result it had a lot of corrosion. I used a 3M "Roloc" white finger disc to clean it up. It leaves some swirls but I does a pretty good job.
You need the white version as it is the finest - good for aluminum. A body shop supply place might have them. My local place didn't have the white ones though.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-17-2005, 05:50 AM
vizail's Avatar
Chris
Can you POst some Pix of Your's..!
Vic
Old 05-17-2005, 09:31 AM
Green Skull 006
Jim Garfield's Avatar
Nevr Dull works pretty good on aluminium.
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 05-17-2005, 05:06 PM
By far the shiniest engine I have seen goes to 350HP930.
You can check out his rebuild thread in the engine rebuild forum for complete details, but according to him it takes many hours of meticulous polishing. Of course having the engine stripped down and out of the car helps a whole lot. Having said that, check out eastwood.com for a full ine of metal polishing supplies.
Mike
1986 930
Old 05-18-2005, 09:03 AM
vizail's Avatar
Thats's waht I'm talking about.! How about some Fan housing and fan?
Great
Vic
Old 05-18-2005, 10:32 AM
vizail's Avatar
If one of you Guys have a nice polished Cooling fan and housing i'll really like to see it. Also I'm planing on giving a nice luster to the babanas
Vic
Old 05-18-2005, 02:29 PM
Zeke's Avatar
Have your case cleaned at the shop where they have the "dishwasher." Then, if it's aluminum, you can work on the surface using a solution with lye in it. Plain old laundry style lye. It will eat your hands and bleach your driveway, but caustic cleans AL nice and bright. Also most non-ferrous metals. But, if you have a mag case, paint it.
BTW, as odd as it seems, there are acids that also clean AL. Some acids will darken AL, but a few brighten it. The primary acid is hydrofluoric and is probably one of the most dangerous acids there is. Phosphoric acid is what used to be found in wheel cleaners. Both have been used industrially and, to a lesser extent, in architectural cleaning of aluminum.
So, whatever you do, be damn careful.
Old 05-18-2005, 03:04 PM
randywebb's Avatar
some hydrogen atoms are more closely bound to the rest of the molecule than the Al atom would be; and in others, they aren't
... that's the explanation for the acid effect Zeke noted above.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-18-2005, 03:21 PM
project 911's Avatar
Here's my fan. Lots of wet sanding steps, then buff with tripoli and rouge. It stayed nice for about two days... It looks great, but does require constant upkeep.
Fuel filter before and after-
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 05-19-2005, 07:35 PM
vizail's Avatar
Hey Guys ...great job.
But after all this efirt there's got to be a better way to mantain al this real shinny loook on a Porsche engine .It looks real nice.
There is not much at the 101 Proyect
Vic
Old 05-20-2005, 04:43 AM
randywebb's Avatar
some helpful things:
profile sander with custom made pads
random orbit sander
Scrubbie pads
metal polish compound
Meguairs heavy cut cleaner
Old 05-20-2005, 09:21 AM
vizail's Avatar
Their friend's
This is what I ultimately want..! http://forum.eastwood.com/showthread.php?=283
Cordially
Vic
Old 05-20-2005, 12:40 PM
