Virginia Rocks!
28 tube oil cooler?
Does the 28 tube oil cooler have a better name? I want to start searching for one and 28 is too short for the seach engine. Also what year did these come out, early Carerras?
Thanks!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
try including "brass" ?
You can use the wild card with it to make it 3 characters 28*. You can also use google to search the appropriate forum without these 2 character restrictions.
KB |
Administrator
Why not get a Carrera cooler? Are you doing a period-correct update?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Virginia Rocks!
I think with the real Carerra cooler, you have to move the horns, and wire it for the fan. I just want a bolt on solution. See my other threads for why I want to keep it easy as possible.
I think they came on the 81 to 83SC and possibly the 84 Carerra. Then they changed to the finned style cooler.
As Klaucke said most people refer to them as a 'brass oil cooler'. When I purchased my car it had an after market finned oil cooler installed and it got a small crack in it. I replaced it with the brass cooler and it works very well at keeping temps down. I have been told that if you intend on tracking the car you should upgrade to the finned one, otherwise the brass cooler is ok for normal conditions.
Damo 83SC 'Guards Red' - Sold 1994 993 C4 |
Steve,
The 28 row cooler is not as effective as the carrera cooler. You can install the Carrera cooer w/o a fan and moving the horns is a piece of cake. To make things even cheaper, check out the 'off brand' coolers (bigger and cheaper then the Carrera). Just make sure you get good air flow to the cooler (remove lights and duct around) when on the track and things will be fine.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
Damo,
To answer your question my 84 Carrera came with the 28 row brass cooler. I don't know if it was an option or choice between the two or not. I don't think it was but may be wrong. I can't speak to the other carrera cooler but mine works fine in stop and go traffic which in this area is pretty bad. I'm sure Charlie can back me up on that.
Dan O 84' 3.2 Targa |
"primarily radiant cooling"
- I doubt if either of them loses a significant amount of heat by radiation. Has to be a different reason.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I do however view the installation of a 'carrera' cooler to be bolt-in. if you get the elephant cooler you'll get all of the right parts. the lower bracket is recommended to be welded in but it can be bolted. The relocation of the horns is very easy with some galvanized strap.
Andy |
Administrator
K.B., I think you've got it backwards (although I honestly don't have data to support my point). The Carrera cooler needs airflow to work effectively, which is a limitation in stop-and-go traffic, but not an issue at speed. The 28-row cooler acts like a heat sink, which is good in stop-and-go traffic. Adding a fan will address the shortcomings of the Carrera cooler, but won't do much of anything for the brass model. On track days, the 28-row cooler typically comes up short.
Yup, I did type it backwards.......... Long day. Thanks Jack. Randywebb, Radiant cooling must have some effect, or those Elephant Racing finned oil lines wouldn't be effective. My old house used to have a "radiator" in every room for heat. They looked a lot like the 28 row radiator.
cutting a DE sesson short sucks alot...
SWB |
