Nine9six's Avatar
Alignment & Corner Balancing
Is it me, or does $350 sound expensive for the above mentioned subject?
Any other recommendations on who to take the car to for this service...I am in the East Bay area.
Thanks,
Paul
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 05-24-2005, 03:50 PM
Somewhere in the Midwest
MotoSook's Avatar
That doesn't sound bad....if it's done right. It's not a one hour job that's for sure....I think a fellow "bastard" paid $500+ in the Chicago burb.
Old 05-24-2005, 03:52 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
$350 sounds reasonable. Try it yourself once and you'll agree. I had the fortune to be allowed the use of my wrench's rack and equipment on a Saturday to do it myself. He did that just to let me see the value of a thorough alignment. To do it right takes more than just a couple of hours.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 05-24-2005, 03:53 PM
ttweed's Avatar
That's the going rate here in San Diego, one of the 5 least affordable cities in the country.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 05-24-2005, 03:59 PM
MotoSook's Avatar
Tom, If you can line up enough work for me, I'll move to SD and bring all my tools
Old 05-24-2005, 04:01 PM
Cory M's Avatar
You'd have to sell all of your cars to be able to afford a down-payment, on an 800 sq ft "condo", an hour away from downtown....
Old 05-24-2005, 04:05 PM
MotoSook's Avatar
I know Cory..that's why the "enough work" clause I couldn't move there unless I hit the lotto
Old 05-24-2005, 04:07 PM
Sounds like Paul had a good weekend!?!?!
That's about the right price Paul, I use Custom Alignment in Mountain View, so you may want to call them for a price check. I know that Custom really knows their stuff
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 05-24-2005, 04:10 PM
Southern Class & Sass
Dixie's Avatar
I had my car balanced and aligned last Tuesday for $250.00. That was in Charlotte, NC. They spent quite a bit of time on it, so I thought the cost was fair. Applying the left-coast-cost-index, I'd say $350 sounds like a smokin' deal. Better than I paid.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 05-24-2005, 05:21 PM
HarryD's Avatar
Sounds sorta inexpensive.
I just had mine done (including lowering) for much more. But then again, what do I know, I let Jeff in Tualatin do it.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-24-2005, 08:42 PM
Jeff Alton's Avatar
I paid 400cdn to have a reputable shop attempt to dial in my alignmnet after the install of the coilovers and 935 style bits. Still not right becuase they don't listen too well!! Still have to go back and get it right. Not sure I trust them to do a corner balance! I think I am going to get scales and start doing it myself.
Jeff
www.turn3autosport.com
Old 05-24-2005, 08:58 PM
450knotOffice's Avatar
nine9six,
I just paid about $475 for a alignment and corner balance from one of the best in the business and it literally took him ALL day to do it right.
Here's what he got me:
LF - 501
RF - 504
LR - 814
RR - 814
So it was well worth the money.
Old 05-24-2005, 11:44 PM
Scott,
Where did you have the work done (Steve A?) and what are your thoughts now that you've got a before/after opinion?
Dave
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 05-24-2005, 11:59 PM
fuelie600's Avatar
How about if I get it really close using the Scruggs home alignment and the tripod methods? If I re-index the torsion bars and center the adjusters the full alignment and CB should be a quick process.
Right? What do you think?
Evan
1987 sun roof coupe
Old 05-25-2005, 05:31 AM
durn for'ner
livi's Avatar
Thats funny. Here in Sweden I have been quoted same price as for my Jeep which is about 100 of your money and one hours work.
Sounds a bit fishy to you, does it ??
Markus
Resident Fluffer
Carrera '85
Old 05-25-2005, 05:56 AM
Zeke's Avatar
$250 to $350 is very fair. I'm sure it can vary from car to car depending on what the survey shows. Mine is all new under there and no frozen nuts and bolts. I would hate to work on an original car for a flat rate. One bolt can slow you down considerably. Things break or get stripped when they are old and frozen.
Old 05-25-2005, 07:28 AM
Mike Bonkalski's Avatar
Milt is right! We had a car in for an alignment that was missing an eccentric bolt. Some one just put a standard bolt in it's place! No wonder the guy had all sorts of positive camber. Lots of things can slow down the process.
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 05-25-2005, 07:32 AM
PeteBrown's Avatar
After completing my suspension upgrade of 22/29 t-bars, bilstein sports, turbo tie rods, PG/neatrix bushings, I just paid $200 for an alignment alone plus $40 to adjust loose wheel bearings. I set my ride height at 24.5" front/ 24" rear and given the height and toe (out) he wanted the mechanic could not get less than -2.44 of rear camber. My alignment is:
0.09 front toe in
-1.19 left front camber
-1.19 right front camber
0.02 rear toe out
-2.44 left rear camber
-2.44 right rear camber.
I'm excited to see how she handles in two+ weeks at Beaverun (6/11-12).
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 05-25-2005, 07:37 AM
MotoSook's Avatar
Pete, I'm surprise that you couldn't get less camber than that in the rear. Usually it's the front. The eccentric bolts like to turn in a certain way....they don't like to turn 360 degrees...if your wrench doesn't understand how the eccentric makes the wheel tilt...he might haev had trouble making it tilt out more...maybe it's not the case, but ... you don't want to out rule anything...
and yep...a rusted car or rusted parts is a beotch! It's difficult to accurately esitmate hours for that reason...sure there are ways to deal with broken bolts, studs, etc... but it adds time...sometimes customers understand...sometimes they don't.
Old 05-25-2005, 07:43 AM
