Solution For Squeeky Hood Latch?
Good Evening All-
I searched the archives and found several people who had complained at one point or another about a squeeky hood latch, unfortunately none of them ever mentioned and fix. Well, I too am now complaining about a squeeky hood latch. I have been living with this squeek since I bought the car, and its hard to brag to your friends about how solid your 24 yr old car is when the damn thing is chirping and squeeking over rough surfaces (which is pretty much all roads here in SE Michigan).
I tried a bit of bearing grease, but that lasted maybe one round trip to work. The squeek was back the next day.
Does anyone have a more permanent fix that doesn't involve earplugs?
Thanks,
Chris Bunker
78 SC
Old 06-22-2002, 05:56 PM
Nobody has any ideas? Are you guys just living with the squeeks?
Chris Bunker
78 SC
Old 06-24-2002, 05:58 PM
Information Junky
island911's Avatar
I adjusted one of the little corner adjusters up. . to take out the slack
Old 06-24-2002, 06:03 PM
Doug E's Avatar
Maybe you could bend the tip of the hook a little bit so it doesn't move on the catch?
Doug
'81 SC Coupe
Old 06-24-2002, 07:38 PM
Way old topic, but I recently just figured out what the REAL problem was. Yeah the latch squeeked a bit, and by backing out the corner adjusters it helped, but the real culprit was the switch up by the hinge on the passenger side for the under hood light. The little plunger and spring were squeeking away with very little movement. A little grease and all squeeks were silenced. NOW it sounds like the bank vault that it is.
Chris Bunker
78 SC
Old 05-24-2005, 07:05 PM
19 years and 17k posts...
azasadny's Avatar
Chris,
That's funny, mine did the same thing and it drove me nuts until I figured it out and fixed it! Where are you in SE MI?
Art Zasadny
Learning the bass guitar
www.ford.com
Old 05-24-2005, 07:32 PM
I live in Ypsilanti, and work in Dearborn or Romeo depending on what is going on.
Chris Bunker
78 SC
Old 05-25-2005, 07:43 AM
