Question Blaupunkt Amplifer
I recently purchased a used blaupunkt radio for my car (another original one to replace the original that I broke on day one of ownership).
In addition to the radio, the seller kindly included the factory Blaupunkt Amplifier that came stock on his 1989 911 Turbo. I have a 1988 911.
The amplifier appears to go under the passenger seat (not sure how with the seat motors, etc.).
Any idea if my 911 would be pre-wired to accept this? Or am I looking at running wires, etc. (which I probably won't do).
Any insight into this would be appreciated:
DCN 911
Old 05-24-2005, 12:42 PM
On my '85 the amp was under the foot board (under the dash) on the passenger side. Ypull have to check there to see if the factory wiring is still intact.
Warren & Ron, may you rest in Peace.
Old 05-24-2005, 12:50 PM
Bill Verburg's Avatar
Mine was also under the passenger footboard, but the one I replaced it w/ was much larger and had to be placed under the seat.
Bill Verburg
Old 05-24-2005, 12:53 PM
If the amp is much larger than stock(wattage wise) then I would rewire directly to the battery and use the head unit tickler circuit for activation.
Bill Verburg
Old 05-24-2005, 12:54 PM
Dumb Question
Do all 1987-1989 911's have amplifiers - the one I purchased was stock on the 1989 Turbo and (I am told) came from under the passenger seat.
Regards,
DCN 911
Old 05-24-2005, 12:59 PM
