Bigger MC
I’m thinking about upgrading the Carrera brakes on my SC and wondered if anyone has done this using a 23mm Master Cylinder. I understand that MB has a 23mm truck MC that requires some modification but haven’t been able to find out exactly what that means? Any other recommendations? I’ve done the usual searches, but have not found much other than it’s a good idea with larger calipers.
Limbo
What year is your SC? If it has Power assisted brakes (a brake booster) you can use the '78-'79 930 MC and it works perfectly.
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
MBruns for President
To Carrera brakes on your SC ? No need to change the MC... Even with 993 brakes on my Carrera I just used the turbo MC... and they are four piston front and rear.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Actually, it’s an ’82 SC that already has ’84 Carrera brakes front and rear. I’m thinking of going to ’44 S2 calipers. I got them for free, they look like they will bolt up but I’ve read that larger calipers like the boxster 4 pots require a larger MC. Thanks for the turbo tip, anyone know if anything else will work?
It’s a track car, no brake issue at all, ever. Around here it’s called L’Shanderitis (gratuitous upgrades just because) |
Dave,
I've looked into that as well. If you need a part #, let me know. I'll retrieve it. Since you are looking for the un-boosted master, it is the "Merc truck" mc. Apparently it requires a longer actuating rod to get the full travel out of the unit. Steve Weiner and VCI both sell them w/ the appropriate parts. Some claimed that since it's physically bigger, it is a tight fit as well. Others have had to resort to a few whacks from a BFH to make space for it to fit. some threads w/ the Mercedes MC info: Which MC with 930 brakes on a '73? Help: Turbo master cylinder mounted in early car
dave 1973,5 |
Sorry, I was unclear, mine is “boosted” as I believe all SCs were. I need/want a bigger MC for a boosted system
Dave, I can’t edit my post and I forgot to say that I read your references and see that the 930 is probably the best. I did try a “search" but didn’t get those two or any others on point for that matter. Weird, I do better with Google searches.
again - I have a boosted MC also - 930 MC - S4 is the same virtually as the 993. I also have 993 rears with a Turbo rear rotor.
Limbo
Ditto on Jeremy's setup. I have the same thing with the 930 MC and the balance and pedal feel is excellent.
Search on his name or mine and you should be able to find our threads with all our upgrade info in them.
Thanks to all. 930 MC it is, and I see PP has them
Here's what you're looking for Dave:
Turbo master cylinder, 23mm |
Even w/ the smaller Brembos which do need the 23.8mm m/c it presents a problem to those w/o a very strong leg. As mentioned you would want a '78-89 930 m/c for your SC IFF you go to Bremo or similar calipers.
Limbo
Trust Bill with your life when it comes to brake advice....
I did and my system came out great....
