Oh No, I split my Carrera Calipers
Well, I while back I split my nice set of Carrera Calipers to rebuild them and get them all cleaned up. I then found out that splitting the calipers is not one of my best moves as the work to get them back together is not trival.
However, I have succeeded. There are two issues when splitting the calipers, the o-ring seals that fit between the halves and the bolts that are used to hold them together. O-Rings: The o-rings are readily available if you know where to look. They are part#901.351.928.10 and only cost my $1.35 a peice. However, they were on backorder and took a while to get 16 of them. A bit pricey, but they are the correct part. Bolts: My original bolts were a bit pitted and had seen better days. However, the original bolts are M7 and M9's and impossible to locate replacements. I therefore converted my to standard sizes, had the holes bored out a little bit, and fitted them with 12-point high quality ARP bolts. These are also a bit pricey, but are very strong. I also had the caliper halves powdercoated red and all the hardware gold zinc plated. They look stunning to say the least...take a look. -Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
Man, you're doing some top notch work on that car! I can't wait to see it all together!
I hope I can do somewhere near as good a job with my 911.
Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" |
Nice work, Britain. you may have run across my saga in a search. The seals ...? they aren't in PET and I really looked hard for them; can you tell me anything more about them? patkeefe found some nice ones and he was so generous as to send me a set in the mail, but I don't think he got them through a porsche part number.
Nice Dryer, I have the exact same one
Andy |
Those pictures were a bit dark, here they are again a little brighter.
-Britain
Wow, they look great! If you were to do another set would you split the calipers?
Warren & Ron, may you rest in Peace. |
-Britain
-Britain
if anyone is interested here is my SAGA. It goes on and on, maybe just read the first and last posts, if you are interested: split calipers - seals - Warren?
Andy |
I wonder if Pelican or Stoddard could get the part (and bolts).
Can your local Porsche dealer and ask for that part number for the o-ring seals.
I read the entire thread on your dilema about splitting your calipers. That is what got me worried. -Britain
Will program for food
I split mine and also powder coated them. They have been sitting for months just waiting for me to reassemble them.
Did you use any assembly lube on the o-rings? What torque did you use on the bolts?
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Use Brake cylinder paste or equivalent on the seals
As for the bolts, torque them to 7ft-lbs first starting with the inner two bolts. Then go to 17ft-lbs all around. -Britain
Thanks Bill.
Thanks also Britain. Have you leak tested the calipers? I am wondering if mine will hold up under pressure...
The is absolutely no reason that I can see why they wouldn't. I haven't leak tested them yet, but will get around to it. We do this to 914 calipers all the time and have no issues.
-Britain
Been here, did this. I split my RR calipers for my 75 911s. I went to Jim Ellis Porsche and they had all the o-rings you could want. Give them a call - 770.216.7590. tell em I sent you. I just bolted them back together. There is the thing with the bolts, tho. They are NOT M40's, nor anre they M30's. They are a special fastener called Ribe. I finally found them on the web. You will strip them with anything else.
Kelly Bell 72 MGB 75 911S 00 Volvo S70 |
Kelly,
thanks for the info but I did get the o-rings there a while ago. The calipers have been sitting in my garage just waiting to get reassembled. You wouldn't by chance have the RIBE fastner, would you???
Alexander Associates, Inc. 4190 Telegraph Road, Suite 2600 Bloomfield Hills, Michigan 48302 U.S.A Contact: Alex Godis Tel: +1 248 594-9900 Fax: +1 248 594-9905 E-mail: agoldis@alexai.com RIFAST Systems, LLC 3550 West Pratt Avenue Lincolnwood, Illinois 60712-3798 USA Contact: Russ Hartman Tel: +1 8479338541 Fax: +1 8476778862 E-mail: hartmanruss@aol.com
Warren & Ron, may you rest in Peace. Last edited by RickM; 05-26-2005 at 12:03 PM.. |
yes, I do still have the fasteners. I had to buy the 3 tool set for $20 + shipping. The guy is a little rude, but he delivered. Get them here:
www.zdmak.com
Greg, I see you are in Ga. If you want you can come by my house to get them. I am in Norcross, just about 4 miles north of 2-85
