Will Wiper arms from a LHD 911 fit a RHD 911
Someone vandalised my wiper arm so I got to get new ones.
Anyones got a parts catalogue to check with over here Many Thanks
1983 911 SC
Old 03-10-2007, 08:54 AM
Grady Clay's Avatar
Peter,
You are taxing my abilities here.
There are two types of wiper arms; one with a straight end and another with an angular end. All cars use one of each. There are two different arms with angle ends; 914.628.314.10 for LHD and 911.628.014.00 for RHD. I suspect the angle is the opposite direction.
The real difficulty may be the wiper motor and crank assembly. They are both listed as different between RHD and LHD. Someone who has recently converted a ’65-’67 right-park assembly to left-park should chime in.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-10-2007, 11:24 AM
RLJ RLJ is offline
Senior Registered User
Did this a long time ago, and only once. IIRC I removed the arm off of the center shaft of the motor, indexed it 180 degrees and put it back on. This lets the arms stop on the other side. As I said IIRC.
Best,
Randy Jones
1971 911 "Iris"
Old 03-10-2007, 05:29 PM
THANK YOU!
Originally posted by Grady Clay
Peter,
Best,
Grady
I really appreciate the help so are ones that are straight the same for left and right hand drive.... I'll be checking which one got vandalised!
1983 911 SC
Old 03-10-2007, 08:11 PM
