How much HP for NA 3.2L?
I'm curious what HP gains people have gotten from aftermarket bolt ons for the 3.2L. Seems like there are a lot of claims out there:
Powerflow air intake 10hp Powerchip 20hp B&B headers and Muffler 22hp With base HP for 84-86 being 207 these upgrades would bring the total to 259. From reading here it seems most these claims are quite a bit exaggerated. 911 performance handbook mentions a car with Autothority A.P.E. Mass air flow sensor, SSI heat exchangers, and stock muffler with 236 hp. What gains have you found? Jim
85' 911 Coupe sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob... |
You can't just add them up (unless you work in marketing for a seller for such items...).
For add-ons, the engine will be "cam-limited" - a hotter cam can make more power (until the engine becomes intake or exhaust limited, or...). The problem there is the shape of the torque cruve, driveability, detonation, emissions, _longevity_ etc. It's all in what you are trying to optimize.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
In my opinion, my 3.2L is about maxed out for hp with bolt ons.
Here's my motor today: Stock 3.2L motor Autothority MAF with chip Dansk euro pre-muffler Stock muffler no A/C I dyno'd the motor last weekend. If you do a search, I posted dyno charts. On the dyno I used, the hp was roughly 204 at the wheels/240 at the flywheel. Dyno showed a rich mixture. Next step is a custom chip from Steve W to get the last bits of hp and get the mixture right. For the exhaust side, replacing the cat with a euro pre muffler yields the biggest gain. SSI's and B&Bs are really nice but not worth the money from a $/hp view. IMHO. Intake side. I really like the MAF. Once I got it working properly, the car runs really nice with it. Throttle response is far better than with the stock air meter.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Add a K&N Filter, it will add 10-15% in HP.
I did it! No really, don't do it!
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
PRO Motorsports
The absolute best bang for the buch on a 3.2 is exhaust, and a custom chip to get the most out of that exhaust.
SSI's are good, but are too small for a 3.2. The exhaust ports on a 3.2 are 38mm. SSI's are only 35mm. Either go with a Euro pre-muffler in place of the cat, and a sport muffler, or a cat bypass pipe and a sport muffler. Either of these will be easily reversible if you need to smog it. If you don't have to smog, then a B&B or GHL header sytem with heat, and a custom muffler will bring the best performance. On my own car, I installed 993 heat exchangers and ran them into an SC muffler, then added a second outlet. Sounds amazing, and the torque and throttle response are night and day. I need to get Steve Wong to burn me a new chip to take advantage of the new exhaust. I'm currently running one that he burned me for the old system with a bypass pipe. Don't bother with a mass airflow sensor unless you want to run some very aggressive cams that the flapper box airflow meter won't tolerate. It's not much bang for the buck, and can hurt driveability if it's not tuned correctly.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 Last edited by Tyson Schmidt; 05-27-2005 at 08:03 PM.. |
Anybody have the enlarged throttle body?
Doesn't want/need a 3.6L
stock on left, modified on right The motor is a 3.5L though with a bunch of other mods. Ralph |
A bunch.................... he he he
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Seriously though, on a relatively stock 3.2L the throttle body should be one of the last things you worry about. Better to free up the exhaust first along with the rest of the intake tract before enlarging the throttle body. Get Steve to burn you a chip, he's a good guy and will help you extract the most power you can. Ralph |
There is a guy here in SWEDEN ho is a guru in porsche engines.He build a 3,2 stock engine with carbs that was brake 420 hk,that is cool.Here is a picture.
I bet your car is pretty fast.
I do have a wong chip. Seemed to give a little more hp. More of a smooth acceleration. I have just been curious what other things actually work. Seems on the boards for every thing you might do there is somebody who says it doesn't work. And of course there are a lot of claims by manufacturers that seems quite exaggerated. Quote:
Tyson.
What did you do to get the 993 headers to work? I assume you hooked them up for heat. Was there a weight savings? Why an SC muffler? What about the cat? Got pics? Sorry for all the questions but I'm planning on a rebuild and am looking for an alternative to SSI or expensive B&B type headers. I'll do a search on this next.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
The big issue w/ the 993 oem headers is the orientation of the passenger side flanges
The right headers set is 993 ![]() The right header set is 911/964 ![]() heat will also need to be rerouted
Did you add the bypass, maf and chip yourself? If so what differences did you notice?
durn for'ner
Will a K&N filter really add any power ??
From what I understand the intake is not the bottle neck in the 3.2 engine. Itīs the exhaust part and thatīs where you can gain some HP. Right ??
Markus Resident Fluffer Carrera '85 |
Tyson's right on the $$$ here with the best bang for your buck with bolt-on mods.
The max power any n/a 3.2L will be able to put out will be close to the 250hp mark. This will probably require Euro p/c, cams, fresh valve job, extrudehoned intake runners, some dyno runs to get a/f readings and then a custom chip to match the dyno data etc... Have fun & good luck !!
Johnny Riz 1973 911 Custom Euro 3.2L "Sports Purpose" '10 Subaru WRX-STi Hatch - modded. RGruppe#152 Early 911S Reg.#335 |
I get 219RWHP from a custom exhaust, chip and cup airbox. Everything else is stock. As was mentioned before, it's all in the exhaust and bigger is not better.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
You can get more than 250 hp - longevity will start to come down as you push further...
"it's all in the exhaust" -- pretty much true at first - after you address that issue, you will next encounter a different limiting factor, overcome it, and another... the whole process is based on addressing each in turn (or figureing out which ones in advance). "SSI's are good, but are too small for a 3.2." -I'm assuming Tyson means for a full race engine. (?) For street, partial street, or AX this conflicts with everything I've ever heard from the top builders. John Daniels also says he has extensive dyno data on this, and that his SSIs are fine for a 3.2L used as above. The other fly in the ointment is the resistance of the entire exhaust system - i.e. are you using a muffler or not, and which one. If you have headers and open pipes, the resistance is already low.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 05-28-2005 at 10:54 AM.. |
