twobone's Avatar
What holds up the rear bumper?
It looks like the PO had a fender bender at the driver rear. The bumper sits a bit low (see pic). The fender support under the rear 1/4 panel is broken. If I replace that...what else holds that bumper up?
Old 05-28-2005, 12:17 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Remove the screw that is on the inboard end of the impact strip and you'll see two nuts holding the bumper on.
This is what you should see once the bumper is off.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 05-28-2005, 12:54 PM
These side mounts hold the bumper shock up which holds the bumper flush under the reflector and tailights. Loosen both sides up and lift the bumper up to the correct height and then tighten both sides. (With the bumper attached, of course.)
Old 05-28-2005, 12:58 PM
1.367m later
KevinP73's Avatar
You can actually do the adjustment with the bumper on the car. Just reach up from underneath to get to the bolts. If the shock is bent you will need to remove the bumper.
Old 05-28-2005, 01:07 PM
