lug nuts won't come off
Having trouble getting my lug nuts off. Had the back of the car up on jack stands and was trying to remove the front tires. Well first the front tires were just spinning so I had somebody press the brakes. Got the drivers side lugs loose. Move to passenger side and got one loose, but the other 4 won't come loose. All the other lugs were just moderately hard to get loose. Any ideas how I can get these loose? I have the back of the car down now on tires, but my help is gone and the front tire is spinning again.
85' 911 Coupe
sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob...
Old 07-10-2004, 06:14 PM
Party Member
viejopatron's Avatar
Put the car on the ground - no stands. Immobilze the car with blocks, brakes, whatever. If you've an air wrench, use that. No air wrench? - put a pipe as a cheater bar on the lug wrench and crank it. If a stud breaks, replace it.
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 07-10-2004, 06:29 PM
well that worked on all except one. That lug broke.
85' 911 Coupe
Old 07-10-2004, 06:40 PM
One the broke is the lock nut. I have not treads, but nut comes out about as far as the stud. Any suggestions??
85' 911 Coupe
Old 07-10-2004, 07:04 PM
scottb's Avatar
Can you take a picture and post it? Sounds like you might have to drill it out with a hole saw. John Walker has posted on this subject.
1984 Targa
Old 07-11-2004, 12:32 AM
That's what I'm trying. Most of it is off, but I don't wanna go any deeper with drill or I'm afraid I will go into wheel. Still not budging.
85' 911 Coupe
Old 07-11-2004, 07:50 AM
scottb's Avatar
Here's what John Walker said back in 2001 about removing a broken lug nut:
as you found out, a chisel will damage the wheel. the best way is to use a 3/4" deep hole saw. it slips over the wheel stud, and when it cuts thru the broken lug nut, there's only a bit of aluminum left on the threads that you can pick out with a pointed punch and a small hammer. also works for those lock lugs that have the little holes in the lower part of the nut.
Good luck!
1984 Targa
Old 07-11-2004, 07:54 AM
just go slow when you think you're getting close to the wheel. you might make a tiny mark on it, but the lugnut would hide it.
206 637 4071
Old 07-11-2004, 09:57 AM
How will I know if I start hitting wheel? Will the wheel come loose right away?
85' 911 Coupe
Old 07-11-2004, 10:13 AM
the wheel would become loose obviously, but you will still have to clean the remaining aluminum shell off the stud before the wheel will come off.
206 637 4071
Old 07-11-2004, 11:47 AM
Woohoo! Thanks for all your help. Came off with no damage to wheel. Think I can save the stud, anyone know what size die I need to fix them?
85' 911 Coupe
Old 07-11-2004, 01:04 PM
Sorry for digressing slightly. This thread is for those who don't believe in antiseize on the wheel studs. Sorry to bring up this "controversial" topic but I think it's worth mentioning at this time.
Warviking,
If you're not sure how to proceed after these suggestions, take it to a repair shop and let them remove what's left. If you damage the wheel, it's your dime(s); if the shop does it, it's theirs.
Sherwood
Who is John Galt?
Rondinone's Avatar
On my car the lugnuts are 14 x 1.25 thread (I think). You should be able to get a die for that.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 07-11-2004, 06:56 PM
I think that should be 14 x 1.5 .....don't have my notes in front of me but certainly 14mm...can't remember the pitch.
---Wil
EDIT:
Yep ... 14 x 1.5 mm
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-12-2004, 06:56 AM
BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
I had a lug nut snap in half, so I tried JW's hole saw method to remove the part of the nut still stuck on the lug. It worked great. The photo below shows the part of the nut that snapped off (1), the outer part that started to spin just as the hole saw "broke through", and the inner part that was not cut by the hole saw (3). I was careful, so the wheel didn't even get nicked.
Instead of using a sharpened pick to pull out the inner part left on the lug threads, I wrapped a piece of shop towel over it and grabbed the shop towel with a pair of needle nose pliers. I was able to turn the inner part off the lug in one piece. If you look closely (it's not a very good photo), you can still see the threads intact on the inside of (3).
The lug nut was sure stuck on tight before I started cutting with the hole saw. It wouldn't budge. Anyone have any idea why it should turn so much easier after having most of the lug nut cut away?
One nice thing about this--the lug threads are in good shape, I don't think they'll need to be chased with a die.
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 05-29-2005, 04:07 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
BR
Congrats. As mentioned earlier in this thread: Are you using anti-sieze on your lug nuts? If not, it will save you from future problems like this.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 05-29-2005, 04:16 PM
BRPORSCHE's Avatar
Steve: The car was a barn find that had sat for 15 years. We spent a few hours trying to loosen all the lug nuts so that we could get at the disks and calipers.
The PO had used moly sulfide on some of the lugs on some of the wheels--those lugs came off easily. No wheel had moly sulfide on all the lugs. The nuts on the lugs with no moly were all stuck and needed a lot of torque to remove (4' long breaker bar).
I don't know why anyone would use moly on some but not all of the lugs on a wheel.
-Tom
aka "Wolf boy"
Old 05-29-2005, 04:29 PM
Originally posted by BRPORSCHE
Steve: The car was a barn find that had sat for 15 years. No wheel had moly sulfide on all the lugs. The nuts on the lugs with no moly were all stuck and needed a lot of torque to remove (4' long breaker bar)....I don't know why anyone would use moly on some but not all of the lugs on a wheel.
You've got to love the "barn" finds. I know of one myself, an earlyconvertible vette that he restored, drove once or twice and it has sat again, literally in a barn, full of hay, bird crap, etc. for 25 or so years. And he will not part with it. He also has a 50's motorcycle, same condition. ARGGH!
Did you try PB Blaster and/or heat? I assume that you would be restoring the wheels anyway. I do not know from experience how good (or ineffective) the former is with bi-metal "welding." It is certaining the best on rust though.
regards,
Old 05-29-2005, 04:51 PM
BRPORSCHE's Avatar
We used both heat and PB Blaster on all the stuck lug nuts, so I don't know whether one or the other alone would have hworked.
After heating, we quickly tightened and then loosened the nuts. except for the one in the photo, they all eventually came off. What a pain.
-Tom
aka "Wolf boy"
Old 05-29-2005, 05:08 PM
Air Medal or two
afterburn 549's Avatar
20/20 hind sight.......get a torch! makes life ez with nuts and bolts...they see it and start jumping off!!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-29-2005, 08:43 PM
