TCB TCB is offline
TCB's Avatar
Window track
My driver's side window came unglued at the bottom where it is pulled down and pushed up. I don't know the exact name but it holds the window at the bottom.
What is the best glue to use to re attach. I was thinking of silicone but thought it best to ask here.
This is also a good time to lube up all the mechanism inside the door. As a side note NO RUST! I am happy!!
Old 05-30-2005, 08:24 PM
don911's Avatar
When that happened to me, I used the same adhesive/sealant used to install windshields. Any winshield place should be able to sell you a tube.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 05-30-2005, 09:14 PM
TCB TCB is offline
TCB's Avatar
window track
Thanks Don good idea. Did you go through and lube up all the mechanism? If so what did you use..
Terry
Old 05-30-2005, 09:40 PM
