Squeak in driver rear
I have a squeak in the drivers rear. Driving the car, it sounds like a squeaky seat and when you push down on the car from the outside it sounds like it is behind the rear wheel.
Is it a bushing or wheel bearing? I think bushing, but I am some what of a newbie on the 911. If it is the bushing, what is the best one to replace it with?
Old 06-06-2005, 06:05 PM
dimps8's Avatar
Time for Chucks' Elephant Racing Poly Bronze bushes!
Damon Harris
66 912 coupe
Old 06-06-2005, 06:10 PM
It's taking all the control I have to not make a smart aleck comment about a "squeak in the driver's rear"...besides, this forum is too mature for that sort of thing.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-06-2005, 08:35 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
Sorry I couldn't resist.
Seriously, sounds like the bushings. First, ou can try a spray lubricant first, something with a nonsticky residue like tefon.
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 06-06-2005, 09:04 PM
Information Junky
island911's Avatar
Re: Squeak in driver rear
hey, what you do with the rubber-ducky is your own business.
okay seriously... "it sounds like it is behind the rear wheel."
Do you mean, in front of the rear wheel?
If the squeak is behind the rear wheel, you may need polybronze bumper bolts. (tic)
Old 06-06-2005, 10:02 PM
I did not even think of it like that, that is funny. I guess I need some oil on my rear! No, wait.
Will strawberry jelly work to put on the bushings?
11 PTT
88 Carrera Coupe - Gone, but trying to buy her back
Hook 'Em Horns!
Old 06-06-2005, 10:05 PM
What is the time needed to replace these? I would like to do all of them when I do it.
Also, what would most shops charge to do something like this.
11 PTT
Hook 'Em Horns!
Old 06-07-2005, 09:08 AM
What do you have to take off?
How do you get it in there?
Can someone post a picture of the area in question...............please?
Old 06-07-2005, 09:26 AM
Semper drive!
rcecale's Avatar
Good grief! This wouldn't be tolerated over on the OT Board!!!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 06-07-2005, 09:32 AM
Randy
What?
I don't want to open a can of worms like......take the tire off, take the brakes off, pull the bearing, pull the axle, replace the boots............etc.
What's the KISS method on this one?
Where do I squirt the teflon?
Old 06-07-2005, 09:42 AM
alf alf is offline
alf's Avatar
You might also want to check the sway bar links and bushings for friction.
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 06-07-2005, 10:03 AM
I was thinking about bushings and typed bearings..............I hate when I mix the two up.
Old 06-07-2005, 10:21 AM
Chuck Moreland's Avatar
If it's coming from the spring plate bushing, and its an original rubber bushing, then the likely cause is metal-to-metal contact between spring plate and spring plate cover due to a deformed bushing. You can see this visually from the outside. In this case grease is useless, you need new bushings.
If it's a plastic spring plate bushing, there is your problem. Replace them.
If it's coming from the sway bar bushing, grease may provide temporary relief but you should just replace the bushings - they are cheap and easy.
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-07-2005, 10:25 AM
Information Junky
island911's Avatar
LMAO
Old 06-07-2005, 12:19 PM
