-   -   wiper challenge - anyone have an idea/ (http://forums.pelicanparts.com/porsche-911-technical-forum/224607-wiper-challenge-anyone-have-idea.html)
mjshira 06-03-2005 09:59 AM
so last night, in a major rain, my wipers stopped working. I was driving the future Mrs. back from the airport about 100 miles from my place.
good thing I have a habit of using rainx!
anyway, I checked the fuse, the fuse connection and both are fine, also.
http://forums.pelicanparts.com/uploa...1117817733.jpg
I have power to the switch also.
fuse panel connections are good
http://forums.pelicanparts.com/uploa...1117817872.jpg
Before I go and remove the fresh air blower to get to the wiper motor has anyone got an idea about what I should be looking for?
The car has been very well maintained but the wiper motor is probably 30 years old now...
widebody911 06-03-2005 10:04 AM
Remove the speedo and/or clock and try jumpering the wiper connections directly. When I got my '77, the wipers would blow the fuse in the first position, but not the others. Turned out the relay had been mis-wired, and I was able to fix it from the passenger compartment.
jpnovak 06-03-2005 10:05 AM
James, You will be able to access the wiring points to the motor behind the speedo and clock. I would look there to see if you have voltage. If so, the motor probably gave up. you could try to turn them on and force the wiper by hand to see if its "stuck'. Another thing to check is that hte linkage is not binding.
mjshira 06-03-2005 10:08 AM
thanks guys, I will check that.
I was manually triggering them when the suddenly wouldn't work? strange huh. I will pull those bits and see what that gets me. The urgency is that if I can't fix this I'll have to take my old truck to run her back the airport and that for 250 mile round trip ain't fun! too slow, too much fuel.
anyway, let me examine that area and see what I find. BTW what does a wiper motor run these days anyway?
mjshira 06-04-2005 03:59 PM
it's fixed!!!
so I removed the gauges as recommended (thx Jamie)
http://forums.pelicanparts.com/uploa...1117925075.jpg
and before I could even get the power tested grounded and ready I saw the ground plug at the wiper motor and noticed it was not connected :mad:
http://forums.pelicanparts.com/uploa...1117925147.jpg
it's nice when a job is that easy! thanks for the tips fellas. while I had the tools out I mounted some new bling to the decklid. Not sure if I am sold on this look but you guys let me know what you think.
http://forums.pelicanparts.com/uploa...1117925288.jpg
when the new engine is in a 3.6 emblem will be added to the free space towards the right side.
mjshira 06-04-2005 04:00 PM
if anyone has an idea on how I could get the grill in this decklid chromed please let me know.
kqw 06-04-2005 04:49 PM
Great you found the issue...Don't ya' just love it...
Also, I noticed that you mounted your badges directly over the center of the grill. Careful not the inhibit too much air flow to the A/C condensor under the grill. Many folks mount badges to the upper right or left...minimizing the interuption of air flow. http://forums.pelicanparts.com/uploa...1117928865.jpg
mjshira 06-04-2005 04:53 PM
thanks. I don't have a/c so I don't think this should be a problem. Also, since it is a 964 tail I can deploy it and get more air
http://forums.pelicanparts.com/uploa...1117929191.jpg
kqw 06-04-2005 05:00 PM
Don't tell me that you retro'd a 964 tail. How in the hell did you do that...Don't answer that....I know it was quite involved and I'll search the threads....
thanks
mjshira 06-04-2005 05:28 PM
http://forums.pelicanparts.com/uploa...1117931180.jpg
go for it man, its a great up grade. check out Thom F's page.
if you look close enough you'll see my third brake light
lateapex911 06-04-2005 05:46 PM
I love that R Gruppe badge! It look so....."right"! I wanna be in the R Gruppe!
mjshira 06-04-2005 06:19 PM
send a note to Cris.
thx 4 the kind words
kqw 06-04-2005 11:17 PM
You're Killing me, You're Killing me....(Hank Stram..KC Chiefs)
Great info..I'll check it out..
Thanks again
mjshira 06-05-2005 07:12 AM
here is a link to his site
http://www.rennlight.com/thomn8r/
