Sports Purpose 911 Driver
so last night, in a major rain, my wipers stopped working. I was driving the future Mrs. back from the airport about 100 miles from my place.
good thing I have a habit of using rainx! anyway, I checked the fuse, the fuse connection and both are fine, also. I have power to the switch also. fuse panel connections are good Before I go and remove the fresh air blower to get to the wiper motor has anyone got an idea about what I should be looking for? The car has been very well maintained but the wiper motor is probably 30 years old now...
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Remove the speedo and/or clock and try jumpering the wiper connections directly. When I got my '77, the wipers would blow the fuse in the first position, but not the others. Turned out the relay had been mis-wired, and I was able to fix it from the passenger compartment.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I would rather be driving
James, You will be able to access the wiring points to the motor behind the speedo and clock. I would look there to see if you have voltage. If so, the motor probably gave up. you could try to turn them on and force the wiper by hand to see if its "stuck'. Another thing to check is that hte linkage is not binding.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
thanks guys, I will check that.
I was manually triggering them when the suddenly wouldn't work? strange huh. I will pull those bits and see what that gets me. The urgency is that if I can't fix this I'll have to take my old truck to run her back the airport and that for 250 mile round trip ain't fun! too slow, too much fuel. anyway, let me examine that area and see what I find. BTW what does a wiper motor run these days anyway?
it's fixed!!!
so I removed the gauges as recommended (thx Jamie)
and before I could even get the power tested grounded and ready I saw the ground plug at the wiper motor and noticed it was not connected ![]() it's nice when a job is that easy! thanks for the tips fellas. while I had the tools out I mounted some new bling to the decklid. Not sure if I am sold on this look but you guys let me know what you think. when the new engine is in a 3.6 emblem will be added to the free space towards the right side.
if anyone has an idea on how I could get the grill in this decklid chromed please let me know.
Great you found the issue...Don't ya' just love it...
Also, I noticed that you mounted your badges directly over the center of the grill. Careful not the inhibit too much air flow to the A/C condensor under the grill. Many folks mount badges to the upper right or left...minimizing the interuption of air flow.
The Fox Carrera |
thanks. I don't have a/c so I don't think this should be a problem. Also, since it is a 964 tail I can deploy it and get more air
Don't tell me that you retro'd a 964 tail. How in the hell did you do that...Don't answer that....I know it was quite involved and I'll search the threads....
thanks
The Fox Carrera |
go for it man, its a great up grade. check out Thom F's page.
if you look close enough you'll see my third brake light
I love that R Gruppe badge! It look so....."right"! I wanna be in the R Gruppe!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
send a note to Cris.
thx 4 the kind words
Great info..I'll check it out.. Thanks again
The Fox Carrera |
