car keeps coming out of alignment....
ok so this is a 77 and I haven’t touched the suspension yet..
but…. I got the car aligned before I headed from Arizona to California … during the drive home I noticed a slight pull to the left develop… when I got back to AZ I had a realigned.. the guy(who deals mostly with trucks) drove it and said he had no idea how it cam unaligned and asked if I hit a large bump…. (I would define all of that states roads a series of large bumps) so he re- aligned it for free… So now a month later.. I drive up to Washington. 1\2 way through the 1600miles it develops a slight pull to the left again.. The car pulls more under braking… so it’s the front… When the trip is over I notice that the right front tire is worn to indicate that it has some toe-in… What is causing this toe-in to develop… the guy who aligned it said “everything was snug” Please be more specific then “worn out suspension” Thanks in advance -nick
SWB |
Take it to someone like Trueline in Seattle who actually knows something about 911s.
Have them or someone like them do an alignment. Not a guy "who mostly does trucks". Get them or someone equally qualified to give an opinion of what is wrong or right about your suspsension. |
Senior Member
The Trueline guy is grumpy. Be prepared. He's not a "people person." JW sends his customers there. I went there, and my experience was not wholly good. But they probably did a nice alignment. I think they put the lug nuts on (the alloy ones) at about 280 lb/ft, for example.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
- You may have a safety issue. Be really careful - a crash might be in your future...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
You sure you don't have a sticking brake caliper?
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
D idn't E arn I t
Gotta 2nd Doug and Byron at Trueline. They're grumpy till you accept the pricing they quote.
I'll never take mine anywhere else. rjp
In the movies only bad guys sleep in king size beds. |
Another suggestion for a Porsche guy that does it right the first time is Monty at Redmond European. |
Randy could you tell us why you think that? |
The guy may have left a fastener loose. (note the poster says 'develop' -- implying it changed while driving).
Even if not, severe mis-alignment can alter the handling - so the issue there is can the drive predict and compensate in an emergency (when he is not thinking about it).
i just was under the car... nothing is coming loose... but i have other issues.. so i will look into it when i deal with those things...
the car still tracks down the road.. the light drift to the left could be mistaken for a grove in the pavement is so light... im going to have to give Monty at Redmond European a call to talk about a few other issues... namely the smoke pouring out of my car under braking... suspension is due this summer... so i will address the issue when i have time... i was wishing it was a "its your dinglehopper, easy fix" kinda question
SWB |
