ejames19's Avatar
Exclamation Proper plug gap for "81 SC
Doing the distributor cap, rotor, wires and plugs this weekend. Picked up NGK BP 7 plugs and Bosch for everything else. What is the proper gap for the plugs, been reading around and cannot get a consensus. Owner manual in German being a Euro spec car (makes a difference I believe in proper gap) and am waiting delivery for another week on a 911 maintenance book. Anyone?
'No illusion is more crucial than the illusion that great success & money buy you immunity from the common ills of mankind, such as cars that won't start.'
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-07-2005, 05:29 PM
walt's Avatar
According to Haynes .028-.032 in.
Walt
82SC 3.0
81SC 3.6
Old 06-07-2005, 05:40 PM
Registered abUser
TerryH's Avatar
Per owners manual
Plug: Bosch W5D
Gap: .028" / 0.70mm
'81 911SC Coupe SOLD
Old 06-07-2005, 05:41 PM
ejames19's Avatar
Thanks for the quick feed back. Do you think the NGK 7's will run to cold or will be fine. I found this plug to be very common choice among all PO in varying models and years.
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-07-2005, 05:49 PM
Registered abUser
TerryH's Avatar
Should be fine. The two plugs cross reference as equals.
Make sure the terminals are screwed on tight at the tips. Use dialectric grease inside the boots. I usually put a drop of engine oil on the threads. Only change on cold motor.
Old 06-07-2005, 06:07 PM
ejames19's Avatar
Thanks for the tips. Will do, let you know how all went on Sunday if I'm not back on here an hour into it on Saturday. Thanks again.
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-07-2005, 06:21 PM
