Nine9six's Avatar
A/C Recharge???
Can any of you East Bay fellas direct me to someone who can recharge my A/C. I believe my car still is using R12. Also, before recharging, should I replace the receiver/dryer? I see both units being sold new on ebay for about $30. Are these acceptable units?
I know R12 is going to be scarry expensive.
Thanks,
Paul
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 06-07-2005, 07:02 PM
Nine9six's Avatar
bump...anyone?
96 993 C2 (Current)
Old 06-08-2005, 06:20 PM
strother's Avatar
I just recharged my 82 SC. Didn't need to replace the receiver/dryer, and the system was empty. Now I've got cold air. The freon itself cost me $120.
1982 Platinum Metallic 911SC
Old 06-08-2005, 07:08 PM
bigchillcar's Avatar
can't direct you anywhere, but unless you've switched refrigerants i don't believe you need to change out your receiver/drier. just get the system charged. you can get a leak test performed, but if you know that you don't have barrier style hoses, then you know that your freon is always going to leak through your hoses anyway and require more frequent charging. good luck.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-08-2005, 07:40 PM
kuehl's Avatar
Re: A/C Recharge???
If you don't know how old your drier is, Yes, you should replace it. The drier serves several functions and overtime
if the desicannt breaks down it will clog the expansion valve.
If you found a replacement drier for $30.00 on (cough Epay), go for it, just make sure the ports on the drier match your hoses. 911s through 83 typically have flare fittings and from 84+ they are o-ring. If your hoses are flare and the drier you buy is o-ring, ask the seller if they include flare to o-ring adapters with orings.
Since the ac system does not have a dip stick to check the oil charge, ask the ac tech you find to add at least 4 ounces of refrigerant oil when they go to the charge procedure, and if they are good guys ask them evacuate for at least 3 hours.
Basic AC help here:
http://www.griffiths.com/achelp/achelp1.html
pm me if you have difficulty finding a good East Bay shop.
chow
Old 06-08-2005, 07:52 PM
Nine9six's Avatar
Kuehl,
I tried to PM you....The system says that you do not wish to recieve emails from members of this message board. I think you need to enable PM by clicking on the "User CP" tab and enabling this function.
Thank you for the info...very informative regarding the o-ring and flared fittings. Since I have an 87, I will assume that I have the o-ring style.
If you could refer me to a good a/c shop who will do the job correctly, I would really appreciate it. You can email me directly at pakoury@sbcglobal.net
96 993 C2 (Current)
Old 06-09-2005, 07:06 AM
kuehl's Avatar
Nine9six,
PM is turned on and functioning. Maybe you need a subject in the subject field? Let me know. In the mean time we'll respond on the shop direct.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 06-09-2005, 08:49 AM
