nixter's Avatar
Rotor and Cap question.
I replaced my ignition wires on Saturday and WOW, what a difference! Better everything! Anyways... When I took off the rotor cap I noticed the six copper contacts and the rotor "blade" had a dark gray/black residue which I guess is caused by friction over the years. Everything still works fine but I can't help but think the contacts should be clean. Would fine grain sandpaper be ok?
Thanks,
nik.
1980 911 SC widebody, Black/Black.
1993 BMW M5. Silver/Black.
Old 06-13-2005, 11:54 PM
rfuerst911sc's Avatar
You can try that as a temp fix but for the price of a cap and rotor ( under $20.00 ) in my opinion you should just replace them. You can keep the set you have as a emergency spare. I recently had an ignition miss on my car and replaced the cap and rotor, the old set I took off had what you describe on the cap and rotor,other than that they looked fine.
Old 06-14-2005, 03:06 AM
Nine9six's Avatar
If you can feel (with your fingernail) a step in the contacts of the cap or rotor, its time to replace.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 06-14-2005, 06:50 AM
nixter's Avatar
Thanks!
Also, when I replaced the wires I didn't replace the wire that comes out of the center of the rotor cap and attaches to the cylinder shaped unit directly above the rotor because I could not figure out how to remove the wire from the cylinder end of things, it doesn't just pull out.
Thanks.
nik.
Old 06-14-2005, 08:12 AM
